technically PP2 are staggered wheels (10.5/11) just with the same size tire front/rear. It's a throwback to tradition and bench racing. It's also a nod toward deliberate understeer. "muscle car" == Phat rear tire just because, reasons.So why would Ford make their PP1 staggered? Base and PP2 are squared.
Yeah not really. Our cars tends to understear sona bigger front is what we do at the roadcourse events.Squared is generally better for handling but on the street staggered is cheaper and better for drag racing which is what most people use these cars for.
4. A little extra margin against unskilled drivers putting themselves into a power-induced oversteer condition that they can't handle (especially with forced induction). Sometimes it's enough, sometimes it's not.A staggered car has some advantages for street
1. Easy plug and play after market wheel choices. (Usually 19x10 and 19x11)
2. Lower tire costs. (Some are smaller)
3. Having big tires in the rear helps you for drag racing (also smaller front =less rotational mass)
The simple answer for a moderately powerful front engine RWD car is that the front end is the heavy end, it's the end with poorer camber geometry, and it's the end that gets the whole cornering business started. All three of which become arguments for making the front tires no smaller or narrower than the rear tires.Just as the title reads. I'm hearing the racing guys prefer 275 squared. So why would Ford make their PP1 staggered? Base and PP2 are squared.
it's not like there isn't 30 years of film of Mustang drivers keeping the front and rear axles calmly in-line while exiting grocery and hardware store parking lots.or when driver skill might be a bit suspect.
Why wouldn't grip come down entirely to wheel width? The width is not changing because it still has to cover the same lengeth on a given wheel. 10 inches is 10 inches. Why get 285 if 275 is cheaper?technically PP2 are staggered wheels (10.5/11) just with the same size tire front/rear. It's a throwback to tradition and bench racing. It's also a nod toward deliberate understeer. "muscle car" == Phat rear tire just because, reasons.
Car should have come with 19x10 squared on 275 or 285 width.
What?? The wheel is not gripping the road, the tire isWhy wouldn't grip come down entirely to wheel width? The width is not changing because it still has to cover the same lengeth on a given wheel. 10 inches is 10 inches. Why get 285 if 275 is cheaper?
no reason. Some people want more/less sidewall stretch. If you have a soft sidewall tire (eg. Conti) a little stretch may tighten up the feel and initial turn-in feedback.10 inches is 10 inches. Why get 285 if 275 is cheaper?
The sidewall is stretched to meet a larger wheel width or oppositely the side wall is pinched to meet a narrow wheel width. The contact patch of the tire remains the same though and that's the part that meets the pavement.Then why do people say "stretched?" Isn't it actually stretched to meet the wheel beads?
Tires are measured on specific-width wheels, and this varies by nominal tire size. So "stretched really doesn't apply to the initial mounting of a tire.Then why do people say "stretched?" Isn't it actually stretched to meet the wheel beads?
