PKs
PK's
- Aug 20, 2016
- Gold Coast, Australia
- Peter
- 2018 GT Fastback
So far I have not noticed any difference with the links, although I have not driven far yet. I think they just compliment the other Steeda IRS bits and pieces that have been added. For install I adopted @KermiStang's idea of using an Irwin clamp (see his photo earlier) and a jack under the toe rod knuckle (I guess it is called). Of course there are several youtubes on install but none of them apply any of the supplied grease to the upper bushing or to the outer edge of the lower steel washer where the oem bolt washer is tightened.Nice, I've been looking at these also, will be interesting on how it affects the ride. Make sure you share those install tips
Ive just purchased these Differential bushing kit to add to my Steda IRS subframe bushings alignment kit and IRS bushings support system.
As usual Steeda baulk at supplying any information other than what is on their install pdf. Maybe their contact staff are not knowledgeable enough or it could be a legal responsibility thing.
So grease them up I did.
You may or may not have one side tighter install fit than the other side. I had to use a nylon mallet on the passenger side to take the old one out and again to slide the new one in.. The driver's side literally fell out. I think that this has a little to do with how this part of the IRS is supported before removing the oem link. Mind you, the whole thing won't collapse if not supported but it helps in keeping things lined up as they were.
Other than that it just requires a lot of jiggling things around until the bolts line up and the lower bolt grabs the thread.
