What is needed to drop in a GT350 fuel pump into a GT?
kenand1988
Phoenix, AZ
2020 Mustang GT
Does the GT fuel pump connector need to be modified? I have search our forum and no one seems to give a clear answer.
Thanks
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
'17 S550
Thanks
Just the pump ? Or the whole shebang (both sides) ?
kenand1988
Phoenix, AZ
2020 Mustang GT
What ya mean by both sides?
Yes I mean if I just drop in the entire gt350 fuel pump assembly such as this then what else would I need to do to make it work
Nuked
Morgantown, WV
2016 Triple Yellow GTPP w/Recaros
Rodheavers Performance (small local shop) offers a fuel kit that is basically a GT350 setup.
WildHorse
N/A or GO HOME
'17 S550
kenand1988
Phoenix, AZ
2020 Mustang GT
Yes that's what I'm trying to do use a dual pump setup and since the gt350 assembly comes with 2 and physically fits in the tank I just wanted to know if it was like a direct swap.
Nuked
Morgantown, WV
You will need the fuel pump module, I think they are different?
Nuked
Morgantown, WV
For my plans it would need to be but it's something I can tune with hptuners
I hope you get it all figured out. Love to see options like this being tried.
Grimreaper
Dallas
2017 GT
Dual fpdm and an external filter.
I'd run at least an 8 ga power wire for them too.
The dual pumps will force more through the stock feed line but I'd want all the restrictions removed within reason. A 10an feed is worth the hassle.
deanm11
Northern NJ
Dean
2020 Mustang GT A10
Juggernaut makes a harness that works with GT350/GT500 pumps, working with just the 1 existing FPDM.
Stephen@lethal
2020 Mustang Gt500
Thanks
The connectors are not the same between them, however after all is said and done with getting it setup, you'd be better off going with a return style system with a set of Walbro pumps depending on how much power you're trying to support. Even the GT350 pumps tend to make out quickly just like the GT ones. If you have any questions about any of those setups, I'm always available. Lethalperformance.com
