What is needed -> GT350 steering wheel on 2021 GT?
monte87
NY-SHITTY
Anthony
2021 Rapid RED Metallic GT
Hi Guys,
2021 GT looking to swap a GT350 w RED thingee at 12pm location on steering wheel on, what is needed? besides the wheel lol Does the steering wheel have to be 2018-21 or can i use 2015-2017 wheels as well. Will all the buttons work w GT set up? Can anyone elaborate for me.
Thanks Anthony
P.S> Will i lose my HEATED steering wheel capability?
MAGS1
Somewhere in Middle America
Mark
2022 Mustang GT
Hi Guys,
Thanks Anthony
You need the wheel for 18+, the airbags are different from the 15-17. I believe you lose your heated steering wheel with the 350 wheel. All your buttons swap over, including paddles if you have an A10.
Brian_S550
Chicago suburbs, IL
See username
2015 Mustang 3.7L, 2016 Explorer 3.5L
Hi Guys,
Only the wheel is needed if you have a car with full steering wheel assembly already. You will have to use a 2018+ GT350R wheel (non-R won't have the red centering stripe) since the center hub and airbag attachment area was changed from the 2015-2017.
Thanks Anthony
P.S> Will i lose my HEATED steering wheel capability? Yes.
monte87
monte87
NY-SHITTY
Anthony
Thank you so much for your reply and vid!!!! Greatly appreciate it!
Anthony
monte87
monte87
NY-SHITTY
Anthony
Thanks 4 reply!!!!
Anthony
bassbaritoneca
Phoenix, AZ
Sean
2020 Mustang GT California Special
Hi Guys,
Thanks Anthony
If you haven't done the swap, it is absolutely worth the 45 min install. With 2018+ you will need the 2018+ GT350 Wheel. I was able to find mine during the holidays when Steeda had them on sale for around $500.
The process is very simple and straight forward as in the CJ video. For me, the most difficult process was getting the airbag cover off as it takes a little effort to push the springs in while also keeping everything lined up and pulling on the airbag cover at the same time. Swapping the components (steering wheel controls) was easy. You only need to remember that the components between both wheels are on the opposite sides. You will loose the heated option. After replacing the components on the GT350 wheel, I added them to my GT wheel, boxed and stored the old wheel.
The final product, look and feel are awesome not to mention easier entry into the seat if you are a little on the long legged side like me.
