TheLion
I'm looking for something a little more detailed other than "it handles good". Things like turn in, mild or moderate push (aka under steer), corner exit etc.
I'm going to do a re-work of my PP GT suspension and OE GT350 parts are cheap to acquire. At the present time I'm thinking BMR SP083 springs which are very close to GT350R spring rates and FP Track Dampers which use the same valving as the GT350 dampers. But i'm wondering about how much bar to run front and rear.
PP GT runs a 32 mm bar up front and 22.2 mm rear bar stock. I believe the regular GT350 runs the same 22.2 mm rear bar while the R runs a 24 mm rear bar. Both Shelby variants run a 34 mm bar up front. I can pick up OE bars and bushings cheap so it's a matter of deciding where to start.
Here's where I'm a little undecided. The BMR springs run a slightly (not much) higher rate at 980 lbs/in vs. 914 lbs/in in the rear. So I'm thinking of staying with the PP / GT350 22.2 mm rear bar with the above strut / spring setup unless those running a GT350R are going to say the car over steers with throttle mid-corner (in which case a 24 mm rear bar and slightly stiffer rear rates would reduce that).
Any feedback on how your stock setups work and what you would or would not change and why would be appreciated. I may not get the balance 100% first pass, but I think I can get fairly close then tweak with bars from there. Since I have a PP GT I can play with front and rear bar combinations, but I'd like to get a good starting point.
