Yes, you just have to enable them with ForScan. It's pretty easy, especially on a 19. Ford changed the wiring for FordPass integration so there is literally zero wiring to do, just have to replace the bezel, APIM, and screen with the 8 inch version and do a few ForScan changes.Question if you add sync3 can you get the driving modes. If I could would add it to my base gt in a second. I'm thinking getting it at a salvage yard so I could also get a cd player. I miss that on my 19...
By the way, the CD player is only available in cars with the B&O system so keep that in mind.Yes, you just have to enable them with ForScan. It's pretty easy, especially on a 19. Ford changed the wiring for FordPass integration so there is literally zero wiring to do, just have to replace the bezel, APIM, and screen with the 8 inch version and do a few ForScan changes.
From the manual:
- Sport – Engages when you shift your automatic transmission into sport (S). Sport mode increases throttle response and helps your vehicle accelerate faster, but does not change the vehicle dynamics or stability system.
- Sport + – Best suited for spirited driving. This mode increases throttle response, and if your vehicle is equipped with active exhaust, it takes on a more powerful tone. If your vehicle is equipped with adaptive dampers, the suspension becomes stiffer. This mode has less body motion and more precise steering. Selectable steering defaults to Sport but can be changed using the steering button.
Yeah this is from that thread you linked. Pretty much what I thought. The shifter to "s" definitely adds about 25% or more amped up throttling and much firming shifting. But no traction control changes.Putting the shifter in "S" allows you to use the paddles manually. You need the "mode" toggle to enter sport or sport+ mode.
Edit....
https://www.mustang6g.com/forums/threads/question-re-drive-modes-on-automatic.107441/
Do you know if its somewhat easy on 15-17 also. Also I'm just wondering what I was missing by not using the modes much on the Eco. For spirited street driving I never minded the traction controls on.Yes, you just have to enable them with ForScan. It's pretty easy, especially on a 19. Ford changed the wiring for FordPass integration so there is literally zero wiring to do, just have to replace the bezel, APIM, and screen with the 8 inch version and do a few ForScan changes.
Nope, it's a lot more work. Need to make your own harness or buy one from Hextall. Bumps up the price significantly. Also have to buy an updated USB port/module.Do you know if its somewhat easy on 15-17 also. Also I'm just wondering what I was missing by not using the modes much on the Eco. For spirited street driving I never minded the traction controls on.
Thank you.Yes, you just have to enable them with ForScan. It's pretty easy, especially on a 19. Ford changed the wiring for FordPass integration so there is literally zero wiring to do, just have to replace the bezel, APIM, and screen with the 8 inch version and do a few ForScan changes.
Well, yes you can. But.....Do you guys know if i can add the oem pony floor projection to my 19 gt base 301a package?
But you didnt do any of the actual performance pack mods right? Because the brakes alone are 1200 dollars.PP Dash and Gauges off Ebay $150
$2150 to turn my Base Model into a Frankenstiened PP Premium
