What did you do to your UK S550 Mustang Today
v8hgt
Cheshire, UK
Nick
Race Red GT PP Coupe
In at GT101 to have the Nemesis oil cooler fitted today.
Great service from the GT101 team. Very helpful and knowledgeable, and the new cooler block appears to be very well made so good work Guy at Nemesis.
hinch
uk
Sideways
casual million quid of gt40's in a picture :) i do love those cars even if they're terrible.
v8hgt
Cheshire, UK
Nick
You would have liked this one with the whipple upgrade then
Entai
Bedfordshire
2019 GT kona Blue, A10, Magneride, CP 2. Daily Driver
Fairly sure the Nemesis kit was not designed in house, but is done by another usual name in the modify your Mustang field.
It's the only kit I know of that has the oil take off from the existing place (using a new bock) instead of fitting a sandwich plate behind the oil filter which is not the best solution on RHD cars.
Nemesis just market and stick their label on, i believe.
Guy@NemesisUK
Bromsgrove, Worcestershire
nemesisuk.com
Guy
Project NemStang / Modified UK S550 Mustang GT
We looked at every oil kit on the market for the Mustang and what was being made avaiable for the RHD market. With the design and manufacturing we have been working with a UK company that knows their stuff, as oil coolers are their specialty. All manufacturing / machining of the takeoff plates is done here in the UK.
We originally started out with a two port take off plate right off the block and was going to have a remote oil filter location. However, the factory RHD cast aluminium piece that runs from the block behind the steering rack to the factory water cooler matrix. This cast piece is also used as part of the engine mounting. So, to have a take off plate, engine mount spacers, remote thermostatic filter housing with x4 ports requiring twice the amount of fittings was going to work out quite expensive. We were then looking at the conventional RHD kits with a sandwich take off plate. I wasn't happy with this design. So, working on this we came up with the idea of a thermostatic take off plate from the original RHD oil cooler location eliminating less areas for failure and keeping costs down requiring less components. This was before we were made aware of a similar Australian equivalent design costing ÂŁ700+ Before Shipping, Import Duty & VAT.
This has then been tested for some time before fully being released to known Mustang garages that we work closely with to be able to professionally fit and assemble the kit. It may not be the cheapest on the market and we don't make a fat lot on it as all the components are very high quality being Aeroquip lines & Setrab Cooler Core. We haven't looked to make it the cheapest on the market but hopefully the best.
The main purpose of this kit was as a high performance product and is also an added bonus should you be worried about factory oil cooler failure completely eliminating the possibility of water entering into the oil system and a much less greater risk of oil blowing out externally.
hinch
uk
Sideways
link to your kit guy? i looked earlier on website and could only see the misimoto kits
Supersolo
U.K.
Ford Mustang GT
That's what I look for, in a supplier/vendor.
I'll add I've always experienced good customer service from Nemesis too!
:like:
v8hgt
Cheshire, UK
Nick
:like:
After driving it back home today in the heat at good speed, I can confirm the cooler works as it should. Stable oil temps and slightly cooler cylinder head temps. Job done, I can now use the car as god intended without the constant fear of terminal cooler failure out of warranty.
Guy@NemesisUK
nemesisuk.com
Guy
We will look at getting a listing sorted. We are just waiting on the latest batch of take off plates to finish engraving.
At the moment however, it is a recommended dealer supplied / fitted kit requiring professional installation with custom mounting and assembly of lines etc. Although this is all simple enough, we want to know it is installed correctly, because if it is installed wrong or not the right amount of oil added it could end badly for the engine and the product blamed even though it had been fitted incorrectly.
hinch
uk
Sideways
yeah unfortunately i'm not doing the 8 hour drive each way to gt101 but i am just about to pull my engine for the 3rd time for new pistons and rods so now would be a good time to do it i guess.
slowhand99
Surrey, England
Ben
Mustang GT Vert Race Red ord 26/03/15 del 24/03/16
Nice job.
Strange mark on your sump
v8hgt
Cheshire, UK
Nick
Nice job.
yeah it looks like a crack but thankfully its not. seems to be a very rough casting. There are a few marks on the sump that make it look like it was sand cast by Bronze Age men in a fire pit.
Chappers
Sutton Coldfield, UK
Greg
Toyota Supra MkV - Tungsten Silver
It's been a while since i've posted but in the last few months, i've added steeda lowering springs and painted them green to match my accent colours, added BMR sway bars and lock out cradle kit really impressed with the stance and feel of the handling upgrades, but need spacers so that the front tyres fill out the wheel arch more, either that or new alloys :like: .
i had a few issues using the wrong type of bushing grease at first as i used some pretty watery stuff so it was creaking like mad but got some recommended stuff and it's been sweet ever since.
Kristian87
Super Moderator
Moderator
Newbury, UK
Mustang GT
Nice work Greg, I like you're style - because it looks a lot like mine haha
I now want my springs to be red!
If you're going spacers, IMO 23mm front and 20mm rear is the sweet spot.
