2016S550
I just removed mine. Literally took less than 10 minutes from time I walked outside. Itās very warm and a great time to use a trim tool and not risk breaking tabs. Had windows up and the inside was very warm. Pry the dash trim loose just below the speaker panel and lift it up slightly. Pry the speaker grille loose from front by the dash trim and then work twd the windshield. Remove the two 7mm bolts holding the speaker and unplug it. Secure the plug with gorilla tape and reinstall the speaker or completely remove it. I removed mine but put the 7mm bolts back in so Iāll know where they are as well as the retainer clips. Reverse install the speaker grille and push the tabs back in on the dash above the AC vents.No doubt disabling center is better for music. But wish I knew for sure if any of the numerous sound sources would be impaired by disabling it. I mean some sources don't even exist in some cars and some owners might not be care or use ones they have. 56k+ posts too big a haystack to find any needles in.
Now, I donāt drive a ton of miles but next time iām out (Monday) Iāll make some calls and see how it does. As for the sound there is definitely separation now and I adjusted the position to be front biased and slightly to the right. Sounds good to me.
