I start the storage season by doing a deep clean/purge of my garage, getting rid of any food sources or hide spots before it gets cold. I also look for any holes/entry spots and plug them. After that, I'll place mint bags around the jackstands, exhaust pipes, and one in the car.
I'm still active in my garage throughout winter, so I'll occasionally check for signs of mice as well.
Did you paint them?If the little things (silver rings) bother you :
WD
Looks like he put a correctly sized o-ring back there but I suppose I could be wrongDid you paint them?
Yeah, not gonna lie, don't enjoy gimmicks in cars, but gotta say, the MyColor is pretty sweet with the digital dash.You mean other than you?
I see you got a PP1. How difficult was it and how much are pads, roughly?replaced the front brake pads.
Yeah that's right - I was going to respond with the correct size when I got home, but I didn't want you thinking I was being ignorant ignoring you bothLooks like he put a correctly sized o-ring back there but I suppose I could be wrong
It's all good, I have one of those multipack cases of all sorts of o-ring sizes, although listing the exact size you used would still probably help someone out in the future.Yeah that's right - I was going to respond with the correct size when I got home, but I didn't want you thinking I was being ignorant ignoring you both
I bought a bag as they were proportionally cheaper and I expected them to be a consumable, but the first set has been on near two years now and they still look like new ...
They haven't budged or degraded.
Fit the wheel nuts as normal, push the o ring down the bore, remove the nut as normal. The o ring sits on the flat face of the nut and doesn't get in the way - it comes out of the bore with the nut.
I simply wiped them over with 303 before fitting them (and on every refit).
I know gorillas are favoured on here, but I believe McMard's have a tougher coating that stands up to abuse and corrosion a little better then the gorilla's.
Considerably cheaper to buy in the UK when compared to the gorilla's too ...
The only downside is the visible silver ring on Ford standard black wheels (but its only seen if you get down low) - the nut still contacts the full taper i.e. its not small compromising the clamped area when compared to some other alternatives
WD
good to keep the memories alive and pass them on....Not S550 related at all, but I just recovered some long lost pics of my first drive coast to coast.
My trusty Lexus LS430 going too far up a tree hauling road in NoCal:
Somewhere in OR I think. PCH:
Cars my uncle was building and had built; at his local hanger. He built a lot of planes too.
550 Spider has a flat six vs the standard 4cyl.
Another project:
Rebuilt bike and one of his planes:
He used to race professionally decades ago. Sadly these pics where taken around 2015 , its nearly all been sold off now. He's pretty deep into his 80s. Just can't control them anymore.
It's sad. Yet I'm so happy to have recovered these pics again!
Shot on my very old Nikon.
very easy. there are two pins to tap out and 13mm bolt that fastens a center pin. compress the pistons (i used c clamps on the worn pad ears). a little brake solvent. a little high temp copper grease on the shims.I see you got a PP1. How difficult was it and how much are pads, roughly?
yes. all off, so White on Black.Have you decided on the best MyColor to go with that paint?
Got a set of McGard lug nuts since my Ford Performance ones are already beat to shit after like two services, lol. Same crappy pressed on cap design. McGard ones are much nicer, and seem to be pretty durable. One of the packages ripped open suddenly and they bounced all over my concrete driveway and sustained basically zero damage, so that's a good sign.
WD
Did you paint them?
WD
Although my car is still with Ford, I swapped the rear nuts out before it went in so I’ve just been out the the garage and snapped a few photos for you :It's all good, I have one of those multipack cases of all sorts of o-ring sizes, although listing the exact size you used would still probably help someone out in the future.
The proper cone seat size is why I wanted the McGards for my OEM wheels. The Gorillas I have for my SVE wheels worked good with the smaller taper on those, but were woefully inadequate for the stockers in my opinion.
It was a beautiful drive. The fog got so thick, there was about 2-3 car-lengths of visibility. I had no idea my lights weren't on....gotta read the manual about turning them on manually.@KingKona and @EmCel and Brittany did a drive thru Shenandoah National Forest by way of Skyline Drive. The leaves were way past their prime but I hadn't been up there in quite a while. Here's a couple shots. The fog was so thick (WAY worse than photo, couldn't even see car or trees on far side of road) we couldn't see even 100 ft.
after 1st bath off transporter.
