JohnnyGT
NoVA
'20 Mustang GT, '17 Expedition, '04 LS430
These Nittos kinda suck. Spin show off the line in first. Kick out and more spinning shifting to 2nd. Day and night better than the OEM junk. Stiffer sidewalls than the Indy 500s, but I want to get the Indys back on sooner than later.
I thought they do better with higher road temps, nope.
BabyDoc1012
NC
‘20 Sierra, ‘21 Expedition
Yup, I think that's what I'm gonna do, go with A/S for the majority of the year. I've done 2 track events/open track in them, so I guess they "lasted," but still, dang.
I mean, sure, I wasn't sure what I was getting into. But at the same time, they had 2 fairly light track days in them, nothing too crazy. I'm more disappointed in Michelin's response that no warranty on OEM. I'm guessing Ford negotiates crazy discounts for the tires in exchange of no warranty.
I do like to drive spiritedly, but with 2 track days in 2 years, I think the Pilot 4s is just an overkill to get again. I doubt that for non-at-the-cutting-edge driving, all season Pilots will be great also.
They are still described as "Ultra High Performance" A/S tires, I think the performance won't diminish to a point I'll notice off track.
Michelin does provide the warranty for OEM, because they are covered under the factory warranty. I don’t think any tire manufacturer warranties OEM tires. Had an issue with the tires on my wife’s Subaru Ascent with uneven wear at about 12k. The dealer replaced them under warranty.
GT Pony
Pacific NW
Called Michelin about their Pilot 4S tires the car came with. The manufacturer's warranty is void if it is OEM equipment (which in itself is bull). If staggered set, which the Bullitt came with halves the warranty (if they were new) from 30k to 15k miles anyway.
As someone else mentioned, the OEM tire warranty is covered through the car manufacturer's tire warranty. Pretty much the same with all car manufacturers. You should have got a pamphlet on the tire warranty, and if not it can be found on Ford's website for your car.
I can see why a tire manufacturer would cut the warranty duration on tires that can't be rotated - ie, the staggered setup.
So after 25k miles and couple of the tires worn into the belting (noticed at tire swap, hence why I'm still on winters),
Didn't you have an alignment issue? And it could also be that the Bullitt comes with a more aggressive track type of alignment, which will wear out the inside edges faster.
Modulom4
Montreal, Canada
Pascal
Mustang GT 2018 PP1, Ford Edge 2008 SEL
So after 25k miles and couple of the tires worn into the belting (noticed at tire swap, hence why I'm still on winters), I'm shopping for new. Kind of wanted to avoid Michelin due to this, but Costco has a deal for all-season Pilots for $1200 with install, which is about $200-300 cheaper than I've found tire rack etc.
Therefore probably gonna put all seasons on and keep the winters for only the harshest portions of winter Dec-Feb....
I'm sorry but can't beat Michelin
Gnatsum21
Fort Lauderdale FL
GT 2021 Premium T. Orange - Manual
I wont get Nittos again either.
GT Pony
Pacific NW
My water deionizer got delivered so I can spot free wash my black beauty.
I really like the "Mr. Clean" wash unit that you could install a water filter in, then do the final rinse with the filtered water. It worked great ... and of course they stopped making it. 😒
tosha
Canada
Mustang GT PP1
Which nittos are you referring to? For the street use, indys are simply amazing as long as they get some heat first. Even on a track, they are still fun to drive and wear looks great so far. For the price, it's a no brainer.
S550_Newbie
North Georgia Mountains
Kelly
2020 GT PP1
I know there are people on here that have run them over a year without issues, I think one or two did mention heat issues but also had the ATX30-HD which does sit higher in the battery box but is also larger in general. I have put a couple hundred miles on since install but it's hasn't been really warm yet either. I think the biggest issue with lithium is just don't overcharge them. I think the main reason people use AGM is price although not a lot and just fear of hearsay on the internet.
Keep us posted on the performance, curious. I was recently looking into this myself but kept coming across people and manufacturers stating not to replace your car battery with one.
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
Poor Man's McLaren
To add clarity to this, the Mustang owner manual states that Ford does not warranty the tires that came with the car. But the tire maker does, and there is a separate insert with the OM that explains their warranty.
If you have a claim within the mileage limit, Ford will perform the service at no charge.
At least this is how I understand it.
Bit_the_Bullitt
Ohio, US
Richard
2019 Bullitt
Right, regular car warranty which I drove through last month. :)
And yes, exactly why they cut the warranty, due to inability to rotate and you're losing the ability to distribute the load with them.
Yes, I did have a slight alignment issue and Bullitt is tuned bit different I think. I did have it checked, so maybe I truly do need to find a new alignment shop.
That's kind of what I'm gathering.
I guess my overall post was more of a frustration, looking back Michelin didn't really "screw" me, I guess I was oblivious to the fact of needing new set just about yearly with bit more aggressive driving.
Upside is daily-driving the Bullitt, cause hellz yes. :)
RookieDDZ
Central New York
Brian
2017 Mustang GT
Installed Powerstop Z23 all around. Also did a full detail of the wheels since I had them off. I hate cleaning PP wheels, but they do look great cleaned up.
KingKona
Virginia
Shlomo
2019 GT
God.....I hated those wheels.
Deeply.
200 - Redline360 - 2
