DonnieO
Donnie
2017 mustang gt cs
I REALLY want a Pony Package trunk emblem for my GT. Best looking emblem by far. Can't find an emblem anywhere and even if I wanted to spend $5xx for the whole panel, I would yank it off and put it on my existing smooth panel. Someday, a part number for the emblem will leak or I'll come across a damaged panel with untouched emblem.
Try the parts farm or midway mustang if you haven't checked them out already
HoosierDaddy
Randy
2016 GT Premium PP
Thanks.
On it .............
None now. Will watch. Based on current items, don't see any removed trunk emblems and every full panel (no Pony Pkg) is "servicable" so a lot of money for something I'd be throwing out or trying to sell without any emblem.
Moonhowl
Western NY
Gordon
2020 GT Premium, 2018 Nissan Frontier, 2000 Harley
Put this bad boy on...
How did you attach it to the honeycomb? My Bullitt style grille doesn’t have the pony shaped mounting surface and I was thinking of using superglue to attach mine.
JRV1631
Lake Wylie, SC
2021 Mustang GT Premium, 2021 Explorer ST
Installed these. This is the unlock sequence. It also goes through the same sequence when you open an unlocked door. Accidentally posted these to the GT350 WDYD forum. So far very happy. And the DRL’s are the bright white. The turn signals are sequential like the rear.
BigR4444
NY
2018 Shadow Black GT 6MT
Superglue would probably work.
It was done by Hydrodun.com and they send it to you with 3M adhesive on the back. So you can just peel and stick, and its stayed there since I put it on. I Believe I used an adhesion promoter prep pad as well... They really help
TonyNJ
Northern NJ
www.instagram.com
Tony
2018 GT Premium Coupe, 2020 GT350 Heritage
Installed the Craig's license plate bracket. It's a quality product. Thanks @Bobn57, @tomservo92, @Mach VII for your inputs. Turns out it's the same kit for all the GT, Mach and EcoBoost cars, even though they ask you to choose. The GT350 mounting bracket is different however.
Bikeman315
Myrtle Beach, SC
Ira
Looking good. Now take it off and put it behind the passenger seat. If youā€˜re ever asked about just say oops, I forgot to put it back on after (whatever excuse you can come up with). :giggle::like:
NightmareMoon
2016 Mustang GT PP
I pulled the oil neck off since I'm no longer running the cover. Much better
What have you guys done with the stud for the engine cover? Does it come out easily?
You can see it there at the top of the picture. I wouldn't mind not seeing that
those are coarse threaded screws into the plastic, they’re not moulded in or anything.
To remove them you’d double nut the protruding threads and then unscrew. Shouldn’t be much of a problem. It might take a bit of force to get it started but you’ll be fine.
NightmareMoon
2016 Mustang GT PP
Today I had the local shop do a Roushectomy and Corsa transplant.
EmCel
VA
Em
2016 mustang gt
I'm sic'ing @EmCel on you WD! Girl post up those pink calipers with glitter (powdered aluminum) that adorn your pretty blue car.
Ok so I sanded down my terrible painting skills on my calipers :giggle: and fixed it with that and clear coat on it. Also splashed some glitter on my pinks today. Thanks to @shogun32 for letting me work there today.
16Fastback
RMR 8985
Pennsylvania
Stephen
2016 Fastback , 2009 Ranger 4x4
Not a good picture as car is dirty and still on jack stands from winter mods.
Love the spoiler all the sites say they won't cover up the holes from my 16 blade spoiler which sucks I want on so bad!
16Fastback
RMR 8985
Pennsylvania
Stephen
Do yourself a favor too - add an Outerwears micron pre-filter to the conical; it will save you maintenance intervals, keeps the conical much cleaner, make that conical last practically forever. It will NOT obstruct air flow, don’t listen to any BS myths about pre-filters like the Outerwears.
You'll thank me later when it cuts your conical maintenance down to -0-...
Check this thread for what I’m referencing:
https://www.mustang6g.com/forums/threads/pre-filter.160216/#post-3265100
I have one works great!
shogun32
Northern VA
'19 GT+PP, '23 EB Brittany, '12 Audi S5 (v8+6mt)
