GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
ln the end I stopped tightening because the washers were starting to dig in to the strut brace. The instructions make no mention about what to do here. They can't be set to 35lbft as the torque wrench just keeps on going and going.
Here is what I mean about the inner most nuts / washers.
Thanks.
I had the Steeda STB on my last car and recall buying thicker and larger washers from the local hardware. I think I even doubled up the washers by putting the Steeda washers on top of the purchased ones.
You don't want to over torque because the sheet metal is thin there.
When I put on camber plates, I doubled up the washers still.
Nodster
UK
James
Thanks not a bad idea. I guess thinking about it I should look at putting a washer underneath to fill the void, that might allow the nut to troque down correctly. I dare not go any tighter as you say, it is thin. At least there is no chance of it working loose. :)
Moonhowl
Western NY
Gordon
2020 GT Premium, 2018 Nissan Frontier, 2000 Harley
Mod #30 for me today. I trimmed a bit more off each side of that ridiculously huge surfboard of an engine cover and gave it a little paint. I’m very pleased with the results.
WD Pro
United Kingdom
Lime GT
If those inner bolts aren’t tight I would hazard a guess that you have lost rigidity, even though you have added the strut brace.
The original cowl brace is rumoured to do more than the strut brace and if those nuts aren’t tight, you will be allowing for movement due to the slightly enlarged mounting holes (and possible paint damage around the edges of it arising from that movement).
I can’t advise how Steeda want you to assemble those items, but they defo need to clamp tight.
Defo don’t over tighten them - some guys on here did, then snapped the studs off …
Good luck ! :like:
WD :like:
@Steeda UK @SteedaTech @tj@steeda
Nodster
UK
James
Good luck ! :like:
WD :like:
Thanks. Its coming off tomorrow, I'll pop a washer underneath to fill the small gap on the inner coloured ones, due to the extra brace.
I'll then use two washers on top so that it doesn't dig in when I tighten it up. That should hopefully then torque down properly without it going on and on. đź‘Ť
Bobn57
New Jersey
Bob
1968 Mustang Fastback, 2021 VB, GT/CS
First wash since I applied the Gyeon MOHS EVO ceramic coating two weeks ago. Used my new favorite drying towel from Luxury Microfiber.
this towel is great. I just pulled it across the panels and they were bone dry! here’s the link if anyone. Is interested.
this towel is so absorbent I did the entire car and didn’t need to wring out.
https://luxurymicrofiberstore.com/
usmade75
2020 Mustang GT 10r80
Looks good! what did you trim it with? I thonkmin going to do mine. Your cuts
look good and straight.
mrgooden
Richard
2019 GT
I gotta tell you, that looks crossed or probably not enough threads. I'd go to the Ford dealer and get the nuts they use, those you're using do not look very supportive.
Richard
Jerry Carguy
Michigan 48169
Jerry
2021 California Special Black exterior
Richard
Not sure what you are fastening, but those nuts with a rounded crown appear to be non-standard. Is there blue epoxy coating on some of the threads? This is a common joint thread locking feature. Or, do you see white plastic around the top of the nut? This also is another way to prevent the joint from becoming loose. Let me know as I am a fastener engineer from Ford. These concepts are used when only a shallow height nut is necessary, because over torque-ing will break the nut, not the bolt or stud which is the desired failure mode. You need to know the torque spec. for correct installation.
S550_Newbie
North Georgia Mountains
Kelly
2020 GT PP1
I just finished ceramic coating the new wheels. Taking them and the Nittos to get mounted tomorrow.
More important I just filed a claim with USAA about the fucking pot hole I hit in AR a few months ago. I thought I could just replace the broken bits on my dime but this is way too concerning to ignore anymore despite my shop getting the realignment being back in spec.
I have full coverage with a $500 deductible. This will be the first report ever with them. Fingers crossed it will be fixed without post problems.
You sure that wasn't a sink hole?
S550_Newbie
Kelly
2020 GT PP1
Got the Focal KX3's installed and unpacked the subs and got them in the back. Next is the amp rack and tuning. Also gave her a nice bath and wax.
