2morrow
DesignR/DriveR/RiceEatR
- Nov 15, 2015
- NorCal Bay Area
- Todd
- '16 Mustang GTPP
Went and got a new set of Track-ish tires for cheap.
Installed my Steeda jacking rails will make life better next time I need to jack it up
I had no problems installing the BMR jacking rails s without lifting the car.Me too. I have them just haven't got around to install them. Wheres a good to place to place a jack to get it done?
My PP1 with 30k miles of settling clear my Rhinos just fine. But the newer Rhinos are a different design so maybe a different angle. Also, for anyone considering the new ones that fit inside each other to take up less room when not in use, they are reports of collapsing. Obviously the design that lets one fit inside the other is not as sound structurally all else being equal.; can't say what if anything they did to compensate. Just as obvious, collapsing can't be often or they would be sued to oblivion.Rhino ramps are cheap. They clear the stock, non-pp GT front end no problem. I think the pp front splitter would get crunched though. Can always use the 2X4 trick to get on and off if neccesary..
mine is the ones that set inside, had em a few years. no issues the handful of times I used them, I didnt use jacks with them, I assume if I heard any weird noises id hurry and dip out.My PP1 with 30k miles of settling clear my Rhinos just fine. But the newer Rhinos are a different design so maybe a different angle. Also, for anyone considering the new ones that fit inside each other to take up less room when not in use, they are reports of collapsing. Obviously the design that lets one fit inside the other is not as sound structurally all else being equal.; can't say what if anything they did to compensate. Just as obvious, collapsing can't be often or they would be sued to oblivion.
So Rhinos won't work w/ the Bullitt unless I do the 2x4 trick?Rhino ramps are cheap. They clear the stock, non-pp GT front end no problem. I think the pp front splitter would get crunched though. Can always use the 2X4 trick to get on and off if neccesary..
It could have been done on these as well with about 6" clearance but my old retired ass was not going to lay on the ground. Instead I laid on my nice pro-lift combo ( chair / creeper )I had no problems installing the BMR jacking rails s without lifting the car.
Might just have to try itI had no problems installing the BMR jacking rails s without lifting the car.
Have a look at my thoughts / findings here : https://www.mustang6g.com/forums/threads/magneride-vs-pp1-ride.135168/#post-2805750Does any one know if magnaride has the car sitting lower ?
here is front and inner fender
I swear my 2019 with out magnaride was higher
very nice I would say you are right on they do set lower front and backHave a look at my thoughts / findings here : https://www.mustang6g.com/forums/threads/magneride-vs-pp1-ride.135168/#post-2805750
WD
