What did you do to your Mach 1 today
Boyd
Southeast Tennessee
Boyd
17 F5 Cobra, 93 Fox race car, 21 Mach 1, 23 F150
A few bits changed in 21, or possibly it's a Mach thing. Email the guys who maintain the central spreadsheet
I'm using Livinitup's 21-23 FORScan, and the ACM breakdown is for a 21-23. So perhaps this is one of the changes you mentioned for 21. I'll make an edit to my post. :) 👍
kellyreno
S.C.
Dal
2021 Mach 1
Played with Forscan a little after a full 8 speaker (ctr disconnected) replacement. 2021 Mach 1.
Had read before that ACM 727-01-02 x*xx-xxxx-xx would change my EQ settings. According to my reference, in 21-23 ACM's, it it changes radio presets.
21-23 ACM 727-01-02 xxx*-xxxx-xx is EQ selection.
0= flat
1-4 are for Premium
5-9 and A-C are Audiophile.
Through experimenting, Audiophile is the higher optioned B&O / Sony systems. Selecting one of those bypasses the Premium amp and results in a very quiet, non-amplified system.
So I was looking at 1-4. Mine was set at 0 factory. 1 & 3 did not let my Sirius XM operate... the source select button simply did nothing. 2 & 4 did allow Sirius XM and sounded so much better than the previous 0 flat selection. I chose 2 because it seemed to be a little less severe from the tweeters. And now my chimes are at a much more tolerable level.
Anyways, just wanted to put up these findings somewhere in case someone else needs it down the road. Pretty happy with the setup now without going to an aftermarket amp / sub setup.
Also took the front end off and did some mods to the foglight setup to get a higher adjustment. Needs a pm drive to check.
Thanks for the info! Good stuff. I have to go back and try again. I do not have Sirius, how did 1 and 3 sound? How did you set your driver only/passenger setting?
Boyd
Southeast Tennessee
Boyd
When I changed the settings, the radio defaulted back to AM. I then tried selecting Sirius, and when it didnt select, I went straight back to Forscan. So I never got to test 1 & 3. Its really easy to do, just be slow and 2x check what you're doing. So try all 4 and see what ya like.
For now, I'm only on all passengers, balance centered and fade just behind the seat (where I can hear the rears also) and volume at 1/2. Thats my basis for doing comparisons.
Boyd
Southeast Tennessee
Boyd
info: I edited to put in my FORScan source in my other post. I'm using Livinitup's 21-23 F150 sheet. Some of the S550 stuff out there is a little older than our Machs. This is the best ref I've found for our cars.
spankybranch
Orlando, FL
instagram.com
Geoffrey
2016 Fiesta ST, 2019 Edge ST, 2022 Mach1
Last night I pulled the diffuser off to install the Verus GT350 Strake kit. :
View from behind car, I’ll get some more in the daylight soon:
Finally took some better pictures in the daylight. Can’t say much for performance other than no issues with my 1200 miles of highway driving and 2 day track event at Barber Motorsports Park last weekend. Car showed just under 200*F diff-temp cruising at 80mph and just over 200*F going into cool-down lap at the end of a 20 minute session (both of these are normal range from prior to the strakes). No new/weird sounds or anything noticeable.
The only real report I have is that they are the lowest point at the back of the car and I have already heard them scrape a few times but they took the hit like a champ with only 1 of the 2 times having to bend the center strakes back slightly into position. Similar to learning where I can go with the HP front lip I’m going to need to re-learn with these but shouldn’t take long 😅
Lucky13Cat
Overland Park KS
2023 Mach 1 Purple
Yes Michelin and tire rack both say minimum 10.5” for the 305/30 so I asked for the 295/30 at discount tire. The guy checked their website and showed me they allow 10” rim for 305/30. I agonized about it for 10 minutes and said what the hell let’s go big or go home. 😎 3 2 5’s in the back. It all happens tomorrow!
Prodigal
OKC
2021 Mach 1
SVE MHP1 wheels. 10” front with 305/30 and 11” rear with 325/30
The car feels amazing. 11 or 12 pounds lighter wheels.
looks great. are the wheels 19"? stock suspension?
Prodigal
OKC
2021 Mach 1
I also proved the answer I gave my wife when she asked, "Where are you going to store it in the winter?"
Love the lift. Shouldn’t the tag read “C Wagnn”?
Noleftist
Va
Craig
Audi
Emptied my catch can today
Why would you have a catch can it? Isn’t your engine port injected along with direct injection Also? is there a carbon issue in the engine? One of the reasons I’m going to buy a Mach one is due to thinking that there would be zero carbon buildup issues.
gorditas
Plymouth, MI
2022 Mach 1
Both of my kids (I bought the 21 year old car for them to drive) have names that begin with G. It also is poking gentle fun at the pretentious people who own a $250,000+ ugly SUV. I toot the horn whenever we pass such a vehicle, though that may impose some danger when they are distracted from taking selfies or live streaming on the way home from yoga.
