What did you do to your GT350 today?
knighthawk
Virginia Beach, VA
Brian
2018 F-150 King Ranch / 2017 GT350
You will like them. Trying to get my buddy to go with them. I have the brushed aluminum on mine. What a difference in looks.
Your car was inspiration for me when I had my previous Oxford White GT350. Was going to get the brushed aluminum for it but ended up selling the car before I bought them. Picked up this smoked tint set used in good condition from a user on here and I’ve been chomping at the bit to get the car back and get the wheels on. Can’t wait to see what it looks like.
mavisky
Cumming, GA
Kyle
2018 GT350
No pictures yet, but swapped out the Ford Racing spring and swaybar kit for a full Steeda Suspension.
Dual Rate Magneride Springs
Compeition Swaybar Setup
Adjustable Endlinks front and rear
Front strut mount opened for further camber adjustment with Steeda camber plates (plates were already on the car)
Rear camber adjustment mount
Unfortunately we're boarding a cruise ship next weekend when our next event would take place but trying to get an alignment next week to get the car ready for when I get back.
galaxy
St Louis
'17 GT350
@mavisky I for one am very interested to hear about the spring change. I was on the fence between those very two springs. Went with Ford. Probably no one has a back to back, apples to apples comparison like this and I’m quite interested.
mavisky
Cumming, GA
Kyle
2018 GT350
I will update, but if you're looking for a street car setup thr Ford springs and swaybars were amazing on my car. I am certain I have sacrificed some amount of daily comfort with this spring/swaybar change and I'm OK with that. I will report back once I have more information on just how much.
One_350
Philadelphia PA
Juan
2016 gt350
Did a transmission fluid change today, surprisingly it was very easy to do. The old fluid was very dark so I’m glad I changed it out.
loco_GT350
Tempe, AZ
2017 Race Red GT350
Did you use the factory service manual to figure out how to do it? I’m curious as I’m thinking I would like to change my transmission fluid as well.
One_350
Philadelphia PA
Juan
2016 gt350
No just saw a YouTube video but honestly once you get under the car. If you are mechanically inclined you will figure it out. Remove the fill hole plug first just in case is seized, then remove the drain plug. Let the fluid drain for about 10mins. Install the drain plug and use a fluid pump to add the fluid. My transmission used about 3 1/4 quarts. Install the fill hole plug tight enough that fluid wont leak. Turn the car on, put it in 1st gear and let the clutch go( rear wheels should be spinning), leave it running for at least 2 mins(letting the fluid circulate through the transmission cooler. After 2 mins remove the fill hole plug and add fluid if needed, then install the plug again and this time snug the plug. I believe the torque spec is 21 ft lb but I honestly didn’t used a torque wrench.
DFB5.0
Australia
Mustang GT Fastback
Are you referring to the tape that you used? I'm using some 3m green tape and it barely stays on.
I was wondering about this though, because it's going to take a good few days. But I took PTO this week, so now I'll start polishing tonight.
What kind of tape did you use? 3m claims no tape residue once removed.
That green 3M tape should be fine regarding residue, but as you mentioned, it can have problems staying in place.
Next time you buy tape, have a look at the red Carpro tape or even 3M Precision -
CARPRO Automotive Masking Tape 24 mm (autogeek.net)
CARPRO Automotive Masking Tape 15 mm (autogeek.net)
3M Masking Tape in 1/4", 1", and 2" | Obsessed Garage
I went from green 3M to the red Carpro and it seems more application specific.
sox3
Newark, Delaware
George
2019 GT 350 Performance Blue
Looks good! I kept my original wheels with SC2s, put them on last year for a PA tail cruise.
460Fred
Wyoming
Fred
‘19 GT350 (sold)
Installed the Shelby CS21 wheels today. I absolutely love them and love the look. Debating on whether or not I should keep my OEM wheels or sell them but I absolutely love the slightly different look of the Shelby wheels.
Always keep your stock wheels on a car like this.
autobahnGT350
Northern Virginia
2016 GT 350
Very nice. What size are those tires?
