What did you do to your GT350 today?
trevman2
Shelby GT3fiddy
Painted the Brembos black with white lettering - just waiting on the wheels to be done at powdercoaters:
TX State
Unites States
2016 Shelby GT350 track pack
If the part that won't go in the sub frame is the spacer, the bolt that you install to hold the chassis brace won't stay tight as there is nothing to keep that sub frame from crushing down when you start driving and putting stress on it.
You might want to revisit your installation instructions. The instructions that came with my Steeda front brace indicated
that sometime there may be metal slag in there that needs to be removed with a chisel or file.
Yeah I read that I file might be needed to de bur it. It wasn’t a bur though it was the entire piece of the stamped steel in the way. There was no way I could get it out of there. I’ll see if I can find anything to get it out.
DrumReaper
South East
I installed my front chassis brace today. No way the provided hardware that’s supposed to go inside the subframe was going in so I didn’t put that part in. Hopefully it’s not a big deal.
Are you referring to the Steeda G Brace?... if so, it fits... you just have to advance it into the chassis appropriately. And, it’s important for the function/protection of the part.
TX State
Unites States
Shiftech but basically the same one. I know you are supposed to advance it into the chassis but there was no way I was getting it in there. A piece of steel or some videos call it slag was in the pay and nothing I did wild move it.
DrumReaper
South East
I had a few bumps of slag I removed with a file. They slid rite in after that.
If you don’t use the inserts the piece will compress under the tightening and will deform the unit.
TX State
Unites States
Yeah i don’t think it’s slang. It feels like a circle from when they stamped that piece of the chassis. I’ll get in there and try and fix it.
NoXiDe
GA
GT350
Have you painted them while on the car? Or disassembled the whole thing?
Had I had the skills I do today, I would not have spent 2K for the R calipers. Now that I can do my own brakes, he most likely did the following
1) Jack car / stands
2) Remove the wheels
3) Remove the brake calipers off the rotors
4) Remove brake pads
5) Remove Rotors
6) Full access to mask / paint
trevman2
Shelby GT3fiddy
Painted on the car - only removed the pad pins. I got a good set of small brushes and took my time. This paint is only temporary until I have the downtime to remove them for powdercoating.
HoosierDaddy
Randy
2016 GT Premium PP
If you are going to track it seriously, check the max temperatures powder-coating likes. I think its low-mid 400s. Since many people need 600 degree brake fluid I suspect the powder-coating could get cooked in extreme circumstances.
trevman2
Shelby GT3fiddy
Good advice - I didn't think about that. I am going to do some Autocross if the events ever open back up but not sure about anything else right now.
Cypherious
Winter Garden FL
www.youtube.com
2016 Shelby GT350
Today I repurposed my old Roush trunk toolkit for the Shelby. I'm currently in the process of rebranding the entire toolkit to match the Shelby/GT350 logos. Probably more custom work thank anyone else would do, but hey its keeping me busy during COVID.
Johnnydarkgt350
Hayden Idaho
Jim
2016 Shelby GT350R, 91f150,Lexus GX460 , 1965 Mercury comet cyclone 4speed
Ceramic coated my front wheels so far; and discovered the unsightly rust on the rotors outer edges ; I wire brushed the edges, and wiped up with brake cleaner , then grabbed an old sock the And put my hand in it , sprayed the sock , I used VHT high temp silver and applied that over prior rusted areas and it looks close to new again . ( Of course I used a clean paper towel with carb cleaner to wipe down the flat exposed rotors after)
