What causes rear tire cupping? Nitto g2 555s
markayash
atlanta
Marc
2021 Mustang
If you don't fix the alignment it will happen again..Can rotate them often and help.
loucas-2021
Tamarac, FL
Louis
2021 Mustang GT PP Grabber Yellow
CoPilot says: Cupping on rear tires is typically caused by a combination of worn suspension components, unbalanced tires, and poor wheel alignment. To address this issue, I recommend consulting a professional for a thorough inspection. Based on the severity, they can advise you on tire replacement or repair options1. If you suspect cupping, try the “coin test”: insert a coin (like a penny) into several tread grooves across the tire. If some areas are noticeably shallower than others, it might be cupping1. Keep those rear tires in top shape!
falcongtho3
La.
2003 Mach 1 ; 2013 Boss 302
If you're running a square tire set, make sure to rotate them regularly. If it's a staggered set up and the tires are non-directional you can rotate them from side to side to help with the feather wear that occurs naturally.
Snakebyte
West Central Florida
Nathan
2019 Mustang GT Convertible
Considering the inside only is wearing I'm sure it is not an air pressure issue. That said, could a slight increase in air pressure have worn the center a bit more than the inside edge?
I'm concerned about wearing the edges (one side or both) prematurely, as I have a tire roar on my new tires at speeds less than 50mph. It is as if the rotational mass at about 50 changes the contact patch pressure from the edges and equalizing contact pressure across the tire width.
The roar occurs with my recently installed 19x11 wheels with Nitto G2 555s tires like you have @Metz3020827.
My door tire label states 32 PSI for stock tires, and it recommends a higher PSI when running high speeds. But of course I am no longer stock on diameter, width, or tire rating.
I don't run track days, run spirited, and I pretty much stay within legal highway speeds. So my question to those on this forum is, what is the optimum PSI for this combination, given that alignment is correct?
Thanks for any insight, experience with those who have gotten good, even wear patterns.
ShadesOfBloo
SE Virginia
1980 Datsun 210 wagon, 1992 Nissan 240SX, 2008 Evo, 2020 Mustang GT
They’re nitto g2 555s 305/35r19 on a 19x11 wheel. They’re directional so they’ve never been rotated and they’re down to the wear bars now after 16 months.
I have -2.7° of camber bc I don’t have camber arms and I’m lowered. Is it bc lack of rotation and my alignment ? Do I need to worry it might be something else?
That's a lot of dang camber for street driving. You're lucky your tires lasted this long.
I think 1.5 degrees is a good target for this car.
I like most cars with zero toe, but I'm not sure about my Mustang. It's my only car that has more camber in the rear than the front, and may turn out to be the car that wants a little toe-in at the rear.
The recommended 32psi tire pressure might be fine, as soon as you un-**** your alignment.
Metz3020827
Metz3020827
Arizona
Connor
2017 Mustang GT
You are running a lot of rear camber. I'd drop it to -1.75. I never liked the feel of 2 or more negative rear camber.
I don’t know how to change it and neither does my alignment guy I guess. He said everytime he tries to adjust it it goes back to what it was which is -2 something. I’ve only ran into one shop here in AZ that will align lowered cars. So it’s a pain in the ass.
markayash
atlanta
Marc
2021 Mustang
I did alignments many years ago and Toe end can also cause that. If I remember it was when they were toed out too far
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
He is lazy. It is pretty easy to set the rear camber. There is a bolt on the inside of the camber arm, part of the arm closest to the center of the car. You loosen the bolt grab a 4 or 5 foot pry bar and slide the arm to where you want it then tighten the bolt.
Find a performance shop. I know there are some.
I think factory "green" spec is up to -2.5 or something ridiculous for a street car. Gives a funny feeling when turning. -1.5 to -1.75 is a great area to be for the street. Gives plenty of corner grip and keeps forward grip.
Factory adjustment procedure.
https://www.mustang6g.com/forums/attachments/2016-mustang-rear-camber-adjustment-pdf.98794/
Metz3020827
Metz3020827
Arizona
Connor
2017 Mustang GT
Something I should give a try at home? I’d rather do that than pay for an alignment currently. I don’t think toe is the problem since these tires are pretty much close to being done and they just started cupping. The passenger side camber is worse than the driver side and the passenger side has worse cupping.
Metz3020827
Metz3020827
Arizona
Connor
2017 Mustang GT
I’m not sure if that’s really the problem though. I think it’s the too much negative camber. The passenger side is a lot worse and the passenger side is also tucked in far more than the driver side. Took both wheels off yesterday. I am probably due for an alignment though.
Metz3020827
Metz3020827
Arizona
Connor
2017 Mustang GT
Does the arm adjust in and outwards? Or does it slide back and forth?
K4fxd
NKY
The problem is when you move the camber you also change the toe.
If you want to do the camber it is easy except for the drivers side where the fuel filler tube gets in the way.
Take your pry bar and move the arm outside as far as it will go. Move the top of the tire out. This should end up with -1 degree or so, then take it to a shop and get the toe set. You want .1 degree IN on both sides for a total of .2 degrees IN. This will most likely take care of your cupping problems.
K4fxd
NKY
