Beerdy
I'm running a staggered set up and had Mickey Thompson Street Comps 305/35/20 on the rear using Niche Targa wheels (20x10, 40 offset). I'm also lowered on BMR springs. I didn't have any noticeable rubbing issues before, but today I had identical sized Mickey Thompson ET Street SS installed in their place. Now on some bumps, it rubs a little. Using my finger to feel the clearance, there is at least a couple of millimeters more clearance on the passenger side vs. the driver side, so I assume it's the driver side that is the issue. The car is in need of alignment (no clue why, it was done 7000 miles ago after the BMR springs were installed) which was the reason for the new tires, but my question is whether alignment would have any hope of helping the driver side tire stop rubbing. So many people run these tires on the rear with no issue, so I'm stumped as to why it became an issue when the only change was going from Street Comps to ET Streets. Wheel/tire experts, any thoughts? Between the prematurely worn out tires from alignment, a bad balance on one of the wheels causing horrible vibration, and the rubbing in the rear, I'm quite frustrated with this whole day.
