weird rear turn signal problem on my 2016 gt
jayk2k3
nothern va.
jay
2016 mustang gt
so, when the car is off the rear turn signal works fine, but when the car is running the right turn signal is out of sync with the 3 lights in the housing, sometimes the outer light is brighter than the rest? a week ago I charging up the battery and did not disconnecting it from the car, did I mesh something up? I Tried resetting the computer and disconnecting the battery.
ORRadtech
Atlanta, Georgia
I don't have help for the signal problem. But I'd be very surprised if charging the battery, connected or not, caused any damage.
junits15
MA
Justin
2019 Mustang GT
You’ve likely got a damaged light, when you say “out of sync” what does that mean?
jayk2k3
nothern va.
jay
2016 mustang gt
so when i say out of sync, I mean the middle light is late to turn on. so the 3 lights go like this 1-3-2, instead of 1-2-3. also sometimes the 3 light is just brighter for some reason
jayk2k3
nothern va.
jay
2016 mustang gt
is anything else could cause this beside a bad housing? it wierd because its fine when the car is off
junits15
MA
Justin
2019 Mustang GT
Look for corrosion in the connectors, seems like an intermittent bad connection.
See if this post helps:
https://www.mustang6g.com/forums/threads/tail-light-out-then-back-on.101551/page-6#post-4024945
jayk2k3
nothern va.
jay
2016 mustang gt
Cobra Jet thanks for posting this thread. I'm going to check tomorrow if I have 12 volt or more at the tail light house with the car running and off. Probably just need a housing just want to make sure be i spend the money.
jayk2k3
nothern va.
jay
2016 mustang gt
I read this could be a sign of a bad bcm? I just found out there's a module in the truck for the tail lights I believe? Anyone know more about this module FR3Z-13C788-D, can I just order one, or does it have to be program?
Snakebyte
West Central Florida
Nathan
2019 Mustang GT Convertible
I had a similar symptom on my 2016 car.
IIRC there is an electronics board in the tail light itself which becomes intermittent. There might be a TSB about it. @Cobra Jet is the Oracle on such things.
Thanks GTP!
LOL - sometimes I can’t find my own posts considering the years of material I’ve put on here…
Here’s the SSM - but this was from a while ago, still may apply:
https://www.mustang6g.com/forums/threads/tail-light-out-then-back-on.101551/page-2#post-2393882
Also to note:
I know there’s a board in each taillight housing and the BCM does have some type of controlling mechanism.
This thread may help you out, as I have never messed with Forscan (yet). The post is from a guy in Switzerland, but it sheds some really good info on the BCM and tail wiring.
https://www.mustang6g.com/forums/threads/disabled-sequential-turn-signals.120768/#post-2523035
This thread is from a guy in Germany, but the responses shed more light on the association of the taillight to the BCM.
https://www.mustang6g.com/forums/threads/programing-taillights-mustang-s550.118792/
  • Like
Reactions: GTP
