Weird crunched up hose Ford Oil Seperator
Threebanger
I am legend.
The Dirty South
Bray
2020 Twister Orange GT350
Also, you can turn the fittings. Just be gentle. That's how I got mine to look like the pic in the instructions.
Jeffwels
Pittsburgh PA
Jeff
2020 GT350 Heritage, 2016 BMW X5M
Mine looked the same no matter which way the ends were installed. Run the engine once and the heat fixes it.
GT30fan
GT30fan
Livonia, MI 48150
Andy
2015 F350 4x4, 2019 GT350 , work trucks
Chumley
'20 GT350, '18 GOLF R, '09 BMW 335
This is what I did when I noticed the kink. A simple rotation fixed it.
lenFeb
USofA
Len
2019 Shelby GT350 #K0110
No problem here. You need to find right angle by rotating ends around
20ducks
Originally South Side Chicago
Greg G.
2020 Mustang GT Premium Convertible Rapid Red
I'm seriously considering doing this upgrade. So I can pretend that I know what I am doing help me out with a little info: is the Ford version or the JLT seperator recommended? I need only the passenger side, right? Is this a straight forward installation or should I have a tech install it for me?
cactus_kid
Big Bend Country, TX
Michael
'21 GT (see sig)
@20ducks , I have the JLT's. Both sides. Prolly overkill as the passenger side gets the most oil. If I were to it again, I'd only buy the passenger side. Just my .02
key01
Chicagoland
2017 GT350 now gone to a great home.
I have the Ford passenger side unit and it is very easy to install yourself. Takes 15 minutes
GT350/BT55
No New Jersey
2017 GT350 Conv Pack Avalanche White Stripe
The pass side on mine never has any oil. The other one will collect oil, poss depending on how long it runs at high revs. I think most blow by is at high revs. It’s good to get that oil out or it would normally be fed back in for combustion, which is not.
Also, if you tried to force it on and off a few times, make sure to chk the o-rings are still seated in the connector. If the are not in position or even missing you will need to get a new one. I had an issue with that.
lenFeb
USofA
Len
I have Ford performance oil catch cans on both sides. Only passenger collecting oil. IMO JLT is more functional and easier to remove oil from the can. Just unscrew the can. With Ford catch cans it's a little more inconvenience and more steps/work need to be done to remove the oil. Not a big deal though. It come down to what is your preferences, looking original or more functional.
