There’s 2 problems with this:I thought uncorrected numbers are actually what the car is making at that point and time. Correction factors are used to save and compare results under different conditions to make them apples to apples
This.
I think this was also done about 4 years ago too.cool, I did this about 7 months ago with a V3.
He kept saying on his videos that he had a 1000whp car so I said prove it with a dyno pull to back it up. He wasn't running his car at the track at the high boost level he was on the dyno to get his max. Doesn't matter if you have a 1xxx capable hp car, what matters is what is the combo run at all the time. I run my car in the trim I dyno in or make track passes in I don't change boost or drop seats ect...lol broke the car making glory hits on the dyno. Solid performance, sir!
So did it break or what ?He kept saying on his videos that he had a 1000whp car so I said prove it with a dyno pull to back it up. He wasn't running his car at the track at the high boost level he was on the dyno to get his max. Doesn't matter if you have a 1xxx capable hp car, what matters is what is the combo run at all the time. I run my car in the trim I dyno in or make track passes in I don't change boost or drop seats ect...
He says that it was still running when they pulled the engine. Never said if it was knocking or notSo did it break or what ?
I thought he trapped 154 mph ?He kept saying on his videos that he had a 1000whp car so I said prove it with a dyno pull to back it up. He wasn't running his car at the track at the high boost level he was on the dyno to get his max. Doesn't matter if you have a 1xxx capable hp car, what matters is what is the combo run at all the time. I run my car in the trim I dyno in or make track passes in I don't change boost or drop seats ect...
