sjmurphy34
Hello all,
I recently purchased and installed some new suspension components based on a lot of the recommendations and reviews I've seen in these forums.I decided to go with FRPP track shock and strut kit with BMR SP083 springs along with BMR CB005 and the Ford performance knuckle to toe bushing. I don't have any other suspension mods other than that.
The basics of my car are:
'17 GT PP with aprox 6500 miles
MGW shifter
SVE 19x10 wheels with 285/35/19 PS4s Square
Ford performance power pack 2
Roush axle back exhaust
(new) Ford performance track shock and strut kit
(new) Ford performance knuckle to toe bushing
(new) BMR SP083 springs
(new) BMR CB005
So the problem that I'm having is that as vehicle speed increases there is an audible humming/vibration that can be felt and as I get up toward 70/80 it gets pretty bad. I've uploaded a video on youtube that you can hear the noise here (might need headphones): I can't tell exactly where the noise is coming from unfortunately so it's really tough for me to pinpoint the problem corner of the vehicle. I've gone through and made sure everything is torqued down properly and clocked the bushings with the vehicle on the ground and even swapped out my wheels back to the original PP wheels and tires just in case it was one of the wheels got out of balance or something. None of that seems to help though. It kind of sounds like a wheel bearing issue but I wouldn't think I would see that problem with only 6500 miles and no track use yet, but maybe that is the problem.
I've attached the alignment sheet here: (https://imgur.com/a/MNUQqky) and hereis a link for what I told them to use. https://www.mustang6g.com/forums/attachments/street-handling-bmr-kelly-jpg.292116/ They aren't all spot on unfortunately as they said they got it as close as they could. I was thinking about taking it somewhere else to see if they could dial it in better however I'm not sure if it would fix this issue I'm seeing. The obvious differences from recommended are the front camber is a bit off however the toe and caster are both pretty good. Also, the toe in the rear should be higher. Would either of these be enough to cause an issue like this?
Was hoping to see what you guys thought as there are a lot of smart and experienced members on this forum that are extremely helpful as I'm out of ideas. Thanks!
MGW shifter
(new) BMR CB005
