Vibration at high speeds.
Discussion in 'Transmission & Drivetrain' started by Enzo, Dec 9, 2016.
  1. Enzo
    Enzo Well-Known Member
    First Name:
    Enzo
    Vehicle(s):
    2016 Mustang GT PP
    Nov 24, 2015
    Orlando
    323
    56
    0   0   0
    I have a 2016 GT M6 and when I'm doing over 100mph and in the high rpm i get vibration through the whole car. Currently I have stock driveshaft, i came to a conclusion that it could be the driveshaft and have been contemplating on upgrading to the DSS Aluminum one. Any thoughts?
  2. robertwsimpson
    robertwsimpson Well-Known Member
    First Name:
    Robert
    Vehicle(s):
    2017 GT Convertible
    Aug 15, 2016
    San Mateo, CA
    1,336
    368
    0   0   0
    I think some people have had some luck re-aligning the rear subframe. check your toe adjustments to see where they're set. That will give you an idea of the subframe alignment.
    I am 90% convinced that I want to do the aluminum drive shaft on my car too, because it starts vibrating at about 65mph.
  3. OP
    Enzo
    First Name:
    Enzo
    Vehicle(s):
    2016 Mustang GT PP
    Nov 24, 2015
    Orlando
    323
    56
    0   0   0
    So depending on my toe, would i need to do a subframe realignment or change toe only?
  4. robertwsimpson
    First Name:
    Robert
    Vehicle(s):
    2017 GT Convertible
    Aug 15, 2016
    San Mateo, CA
    1,336
    368
    0   0   0
    if toe on both sides are adjusted in the same direction, it may indicate the subframe is off kilter.
    these might help in that case
  5. OP
    Enzo
    First Name:
    Enzo
    Vehicle(s):
    2016 Mustang GT PP
    Nov 24, 2015
    Orlando
    323
    56
    0   0   0
    I already have those on.
  6. robertwsimpson
    First Name:
    Robert
    Vehicle(s):
    2017 GT Convertible
    Aug 15, 2016
    San Mateo, CA
    1,336
    368
    0   0   0
    time for a drive shaft!
  7. OP
    Enzo
    First Name:
    Enzo
    Vehicle(s):
    2016 Mustang GT PP
    Nov 24, 2015
    Orlando
    323
    56
    0   0   0
    Also forgot to mention I have spacers as well.
  8. robertwsimpson
    First Name:
    Robert
    Vehicle(s):
    2017 GT Convertible
    Aug 15, 2016
    San Mateo, CA
    1,336
    368
    0   0   0
    I am assuming that you've done all the easy stuff like making sure that your wheels are perfectly balanced and using a torque wrench on the spacers and lug nuts?
  9. OP
    Enzo
    First Name:
    Enzo
    Vehicle(s):
    2016 Mustang GT PP
    Nov 24, 2015
    Orlando
    323
    56
    0   0   0
    Yes I've done all that but at normal speeds everything is fine. When I get close to 100 and go faster it vibrates more and more.
  10. CB
    CB Banned
    Vehicle(s):
    2016 GT, Black, PP
    Nov 10, 2015
    Near Pittsburgh, PA
    841
    199
    0   0   0
    Did your car do it before installing the spacers?
  11. OP
    Enzo
    First Name:
    Enzo
    Vehicle(s):
    2016 Mustang GT PP
    Nov 24, 2015
    Orlando
    323
    56
    0   0   0
    To be quite honest don't really remember. I would figure if it's spacers that it would do it any 50 or higher.
  12. Scott Wilson
    Scott Wilson s550 is life
    Vehicle(s):
    Feb 1, 2016
    Central TX
    313
    87
    0   0   0
    I am having the same problem. Did you ever find the fix OP?
  13. codemanstang
    codemanstang Well-Known Member
    Vehicle(s):
    15 GT Prem
    Jun 30, 2017
    OC CA
    379
    55
    0   0   0
    I had this issue, drive shaft eventually got replaced and vibration/noise went away.
    There is a mega thread on vibration issue
  14. Losobaby
    Losobaby Active Member
    Vehicle(s):
    2015 Gt w/PP
    Jul 10, 2015
    30
    im have this issue also with going about 80 plus its like a pulsing vibration
  15. Scott Wilson
    Vehicle(s):
    Feb 1, 2016
    Central TX
    313
    87
    0   0   0
    I replaced the driveshaft and it got a little better but it is still slightly there. I have no idea what is causing it. It's only on throttle. If I let off the gas at 100mph and coast it's not there. But as soon as I'm back on throttle it comes back. Datalog looks good. I'm starting to think maybe it's because I have longtubes and a full 3 inch exhaust so maybe it's just so loud that its resonance when i get under higher load that usually happens in higher gears
Loading...
Share This Page
