Upgraded to power seats on base S550- surprising solution found!
Brian_S550
Brian_S550
Chicago suburbs, IL
See username
2015 Mustang 3.7L, 2016 Explorer 3.5L
This is awesome! Makes sense that the wiring would be in place, but it's great to see the job done. Plus, those tan katskinz cognac leathers are just right! Should have been an OEM color, so much better than the brown that is offered.
I recently changed my seats to a darker brown actually, so the leather seat covers seen in the pictures in this topic are for sale.
G4579
Pittsburgh
2016 GT350 Avalanche Gray Track Pack PBR BLK OTTS
I am trying to swap in a set of power '17 GT seats into my 16 GT350 track pack (Recaros) car. I seem to have a different situation: the 30a fuses for the power seats are in place under the hood (locations 12-14), but there are no power wires at the connection under the seat.
Any idea how to source the pins needed to add the power wires to the plugs?
alex mustang
Austria
Alex
Mustang 6 V6 Conv.
Hello Brian
i want to change the my V6 Base Seats- to Power Seats -
maybe you have the power circuit diagram for my V6 Seats please ?
I have only One Connector under the Seat ?
jdowen2
San Tan Valley, Arizona
jeff
2016 Mustang V6, 1967 Mustang
Can I easily add power seats
to my base convertible?
Brian_S550
Brian_S550
Chicago suburbs, IL
See username
Hello Brian
The wiring diagrams are attached to my first post.
Brian_S550
Brian_S550
Chicago suburbs, IL
See username
I can’t answer that firsthand, since this mod requires splicing into unused convertible top motor circuits, which are also factory installed on fastbacks. I assume that using my method would cause issues with operating your convertible top.
Cmcski
TN
2016 V6 convertible mustang
The funny thing is that I didn’t have to source anything. My 2015 V6 already had that segment of the factory power seat circuit in place.
I did find that the correct sized pins are relatively common in Ford vehicle wiring harnesses, so for any S550’s that don’t have the kickpanel to seat wires already installed, you can simply pull some bulk wiring and spare wire pigtails from a junkyard car for cheap.
I installed a power passenger seat today and now have an airbag light lit on the dash. I did not have the proper plug in my base v6 so I spliced in power directly to the plug half attached to the seat. Any help on the dash light issue would be appreciated.
Thanks
Brian_S550
Brian_S550
Chicago suburbs, IL
See username
The power seat adjustment and airbag circuits should have nothing to do with each other except sharing a ground wire, so I would start by verifying that none of your connector pins were accidentally damaged when hooking it all back up.
Cmcski
TN
Thank you I will check the pins.
Joe B.
Westmont, Il.
2017 Mustang V6 coupe
Brian, I have equipment group 050A, base model manual seat, and like "alex mustang" stated in post #19, there is only one connector under the seat, not two like in your photo. Will this mod still be as straight forward as it sounds, on my car?
Brian_S550
Brian_S550
Chicago suburbs, IL
See username
The green/red and black wires on top of your connector in that photo are the ones that will be used for a power seat.
Cmcski
TN
Not sure why my plug did not have the power and ground on the
I did not have the top outside power and ground on my plug. Just 4 blue filler plugs.
Joe B.
Westmont, Il.
Just to add the info on my '17 V6 with manual seats and 050a equipment group.
The power wires ARE on the driver's side, NOT on the passenger side. The two fuses are under the hood as the OP stated. So unless I get a burst of energy, I will upgrade the driver side only, when I find the appropriate seat track. Picture is the passenger side W/O the power wires.
Joe B.
Westmont, Il.
Just guessing, because yours is a 'vert?
127 - Borla - 1
