Shadowblackbeast
- Nov 15, 2018
- Minneapolis
- Josh
- 2018 Shelby gt350
I’ve gotten reliable information from 2 different sources that there has been some silent but very big changes to the rotating assembly of the voodoo motor starting with MY18.
I’m trying to track down more info as far as build dates etc would be concerned but may never narrow it all the way down. Depends on how forthcoming I can get these sources to be and if they will allow me to publicly name sources.
The changes I’ve been told are to the pistons and ring packs.
The pistons have been modified to tighten up the piston to wall clearance to alleviate the slap that has been a known issue that even ford issued a TSB about. I myself have noticed on my car that there is very little slap that you would have to put your head in the wheel well to hear and if dissipates very quickly. With forged pistons there will always be some movement to cold pistons but it’s negligible on my car. Not sure if any other 18 owners can chime in. My build date is 6/18.
The second change is to the piston ring pack. They switched to steel rings with tighter clearances to hopefully alleviate oil consumption issues that have haunted the voodoo motor.
Both of the changes are good things for the motor as it stands N/A but not so much for boost
There was also mention of water jacket modifications but nothing reliable
Like I said I got this from 2 very reliable sources with access to engineers from ford. Hoping to get more info in the near future.
This also fits ford MO of silently making changes to known issues. So take that as you like
