(unconfirmed) Source of AC Evap Failures Possibly Identified [POLL]
Has your AC failed?
  • Total voters
    213
Lancer37
Utah
Landon
2017 Mustang V6
So from those reporting, there are 187 failures among members of the Mustangg6 forum..? Just for fun I looked at the approximate number of members of the forum (827 pages at 50 members per page), guessed that 75% have S550 Mustangs, (roughly 30,000), and divided divided 187 by 30000. This works out to about 0.62%. Obviously there are a lot of assumptions built in, but it's interesting to me to think about it this way.
packick
Ferndale, WA
2015 Mustang GT Coupe Premium
About a year ago (see May 21, 2019 post) my mechanic thought he had discovered why my 2015 Mustang GT had been losing A/C coolant (refrigerant). He noticed a protruding nub (prong) inside the valve dust caps and believes they were pushing down on the Schrader valve when tightened tight. So he loosely tightened them. I am happy to report that my A/C, which normally looses coolant after a year or less, is performing as-advertised. So in my case, this might have been the cause of my problem.
Genxer
2015 Mustang GT / Perf pack / DIB
Make sure the schrader is tightened all the way. The cap should provide an extra measure of sealing if it’s typical. Weird that it would cause an issue. They usually have an oring inside of them. The high side (pressure) is the smaller diameter line with the larger port. The large diameter line with smaller port is suction side.
GT Pony
Pacific NW
Might want to somehow remove that protruding nub (prong) inside the Schrader valve cap. @Gebxr - the Schrader valve caps do have an O-ring.
Genxer
The cap is def not supposed to depress the valve. Something is off there.
Emilbadal
Socal
Emil
2016 V6 Auto DIB
I replaced my Evap core last weekend with help of my brother in-law. The AC is charged and blows cold again. I decided to go the aftermarket route with the evaporator core and everything else from ford. This is what I believe is the cause of the failure:
- The evaporator core design and method of construction is the root cause of the failure IMHO. The evaporator core seems to be constructed of layers of fins sandwiched together by means of soldering each fin to its adjacent fins. In other words each fin has its headers integrated and then the headers are soldered together. Since these headers have a lot bigger surface area that needs to be soldered, it dramatically increases the chance of leakage due to inconsistencies in soldering. And if you look at the evap core that I pulled out, it's exactly leaking from the soldered area and my guess is that even though Ford changed multiple suppliers and has done multiple part numbers they still couldn't address the issue for good until the last part number which is too early to really tell if they have.
Again this is what I think is happening to these evaporator cores and that's why I decided to go with aftermarket core that had a different design. I hope I never have to go through such repair ever again, because it's such a PITA.
GT Pony
Pacific NW
Any photos of the aftermarket core design for comparison?
Emilbadal
Socal
Emil
2016 V6 Auto DIB
Yep, The brand is UAC. It didn't come with expansion valve, so I bought a genuine from Ford.
Just a fair warning : The trickiest and most suspensful part was to get the new evaporator's pipe and the expansion valve bent into correct position to seat in the housing. But ,that's something that Ford's TSB warns you about the Genuine ford evaporator part also, that you'll need to bend the pipes in order to get the evaporator seat properly in the Housing. Thankfully everything worked out fine. Let's see how long it will last....fingers crossed
Genxer
That is a typical design for modern evaporators, not usually problematic. If it's like the ones I've seen, a material is sprayed all over the core and it is run through an oven where the braze material flows out into the voids. Maybe they somehow did not get good coverage of the braze material.
TundraOnKings
PNW
T
'20 GT PP1 A10, '20 Armada,'15 Tundra,14' GS350F
Are 2020 model years subject to this failure?
Most of the failures seem to be particular to the 2015-2017's. I haven't seen many 2018+ issues posted on this site or these EVAP core threads.
Also to note:
If a 2015-17 owner has issues beyond warranty, call the Ford 800#. Explain the issue and they should help with the repair costs as this is a very well known issue. Others have posted that Ford was willing to discount their repairs.
ydoucare
US
2015 EB Premium
Just had mine replaced on a 2015 EB at around 57,000 miles. Only took 5 trips to the dealer over the course of 2 years to get them to replace it, in which it took them a full month to do the job (paid for by extended warranty). I was driving a Civic for so long I had to re-acclimate my self to my own car when I got it back. Gotta be the worst dealership service department I've ever seen. These idiots couldn't diagnose a blue sky on a cloud-free day.
HoosierDaddy
Randy
2016 GT Premium PP
What dealer for fellow forum members info?
HoosierMustang
South Florida
2015 Ford Mustang Ecoboost
Just had my 3rd evaporator replacement at 20K miles. I've got a 2015 ecoboost. First two were under warranty. 3rd one cost me $2K.
Are people able to call the Ford number post repair and get reimbursed?
