Mine is a 2016, verify with @LevittownFordPartsWhat year mustangs does that cover?
yeah after a few years of thrashing it finally started wearing out my stock 6r80 trans. I’m going to my tuner’s shop Monday to order an Exedy stage 2 kit with intermediate shaft. I will set up an appointment for the uninstall, build, reinstall and tune update. It started slipping yesterday during a wot pull on the street..i knew it wouldn't last much longer..
Billet unit still appears to use a thrust washer. That's where the issue is, not necessarily in the construction of the overall unit. Can you confirm if tye billet unit uses thrust washers or Torrington bearings?Also If you have the coin you can replace the OEM forward planetary gear with a billet version. That's what I did when I had my trans upgraded.
https://www.beefcakeracing.com/msr-planetary-gear/
Are they a well known or reputable installer? If not,...........yikes!Ugh... My installer has had my car for two weeks now, and barely any progress on my Turbo Set up. How long did you all wait for an install? IF Only I was smart (and experienced) enough to do it myself.... Seriously getting Mustang Withdrawl!!!
In the description it says it uses a needle bearing instead of thrust washers.Billet unit still appears to use a thrust washer. That's where the issue is, not necessarily in the construction of the overall unit. Can you confirm if tye billet unit uses thrust washers or Torrington bearings?
Yea that's a huge price difference, lol.Im just gonna go with the stock replacement since its just $45. a billet one is $1400 which is way outta my price range..
Yup, ill just put im a new oem unit every year!Yea that's a huge price difference, lol.
From what I've read and seen, the problem is that when the stock planetary does fail, it takes out the entire transmission. Obviously that will also get expensive. Lol.Yup, ill just put im a new oem unit every year!
