Twin turbo 2.5 vs 3 inch exhaust
FloStang
2017 mustang gt
Hey all, I recently bought a 2017 GT premium that came with some unexpected goodies. Gt350 manifold, mishi intake tube, upr catch can, lowering springs, and a set of Vossen hf2 wheels. I also noticed it has a Roush axle back. I know the Roush is a 2.5 in axle back. Now I plan to order a Hellion Street Sleeper turbo kit and my question is should I keep the Roush and just pick up a 2.5 inch x pipe or should I go full 3 inch. How much hp am I leaving on the table if I stick with the 2.5. Now my goals for now are to be around 800hp with e85 with room to grow later. I'll prolly be ordering the kit and other goodies with the next big sale like 4th of July. Thanks in advance
Advertisement
Furious18
Nevada
2018 mustang gt, 2018 f150 eb 3.5
Turbos create a lot of back pressure. In an ideal world you wouldn’t have anything past downpipe.
coyote heads flow a ton of air. If you have too much back pressure you’ll have issues.
FastCarFanBoy
2013 GB GT
I’m not very knowledgeable about turbos but what I’ve gathered is the stock pipes Won’t be an issue with twins unless your trying to make mega power. The mufflers however need to be as free flowing as possible.
erikkire18
santa barabra,ca
5.0 Hellion TT
You might have to go 3 inch catback. My kit only mounts to a 3 inch but maybe the sleeper kit is has an option of 2.5 or 3. i have top mount
StickShiftyFifty
CA
2016 mustang pp
3 inch cat back with H pipe would be ideal for street, or best would be electric cutouts. Im looking into the cutouts when i get extra $$
Friesian
Alberta
2015 Mustang GT
I just bought a cheap mbrp 3" catback. Mufflers are straight through. Turbos drowned out the sound so much anyways you dont need a expensive catback
wazslow
PA
2016 Mustang GT/CS
Do you have the Hellion kit? I am working on installing my street sleeper kit now. How did you connect the 3 inch exhaust from the turbos to the catback? It seems like all of the 3inch catbacks still neck down to 2.5 inches. Do you cut that 2.5 inch portion off and use/buy 3 inch band clamps? I dont see any clamps in my kit to connect to the catback.
@HELLION TURBO any tips? Am I missing clamps?
Friesian
Alberta
2015 Mustang GT
I have the sleeper kit. Not installed yet. But, yes it looks like you would have to cut the front part off the catback and just weld it there or clamp it.
Furious18
Nevada
I’ve heard of many cars having boost creep or very unstable boost regulation.
[email protected]
2017 mustang gt
I would highly suggest at least the 3inch setup. They do tend to have a bit of back pressure which can in turn cause valve float if its not controlled. Luckily the Sleeper kit is a bit more efficient over the top mount kit. If you have any questions, feel free to PM me. I had a Hellion kit on my 2017.
gimmie11s
SoCal
Murica!
This.
You need to go 3" turbo-back exhaust with straight through mufflers (no chambers) at the very minimum or you will be running into valve float at moderate boost levels 10+ psi or so.
5.oh
Bentonville,Ar
2016 Oxford white 5.0
Or boost referenced cut outs. Pretty affordable and allow you to keep your current exhaust. Have the cut outs open at say 5-6 psi and then boom you create a free flowing exhaust while making power
99Formula
Mechanicsville, VA
Ray
2019 Mustang GT
I’m running the Street Sleeper kit (62/66 Precision BB turbos) with boost actuated cutouts on my 2019 along with a FRPP resonator delete and factory cat-back. There were no signs of any sort of valve float.
The car made 770 to the tire through a MT-82 on 8.9lbs. It sounds stock (other than some turbo noise at idle) until the car makes around 4lbs and the cutouts open. It’s all in what you want, but I’ve built one too many super loud cars and wanted something more docile until I really laid into it.
5.oh
Bentonville,Ar
which boost referenced cut outs did you go with?
Advertisement
46 - Roush Performance - 3
Advertisement
