RPI Designs
- Nov 18, 2014
- Salem, Ohio
- Website
- www.rpidesigns.com
- 2015 Mustang GT - Test Mule
2015 2016 2017 Ford Mustang EcoBoost Kompact Shortie Dual Port Blow Off Valve
http://www.rpidesigns.com/shop/item.aspx/2015-2016-2017-ford-mustang-ecoboost-kompact-shortie-dual-port-blow-off-valve/
No one knows EcoBoost better than Turbosmart. They make performance parts for every Ford EcoBoost application, not just here in the USA but all around the world. But this, the world’s first aftermarket BOV for the new Mustang is truly exciting.
Stock blow-off valves like those that come standard with the Mustang often suffer from a range of problems. They are plastic, and they leak, and if you want to up the power (and who doesn't?) they have trouble holding the extra boost.
You’ll have no such troubles with Turbosmart’s Kompact Shortie blow-off valve. ​Like all Turbosmart blow-off valves, the new Mustang Kompact Shorties have been designed, machined and hand assembled in-house. Keeping the process in-house, ensures only the best quality, and the aircraft grade aluminum alloy construction means cracking and leaking even under increased boost levels will never be an issue.
The Mustang Shortie is produced with a light-weight, brass/aluminium, two-piece piston, which is then perfectly matched with precision engineered springs, giving razor sharp valve response, and a serious increase in performance over stock valves. The Shortie’s dual port design provides one plumb back port to keep the car’s computer happy, and a second vent to atmosphere port for that trademark Turbosmart BOV sound we all know and love.
2015 2016 2017 Ford Mustang EcoBoost Kompact Shortie Plumb Back Blow Off Valve
http://www.rpidesigns.com/shop/item.aspx/2015-2016-2017-ford-mustang-ecoboost-kompact-shortie-plumb-back-blow-off-valve/
The Kompact Shortie may be small in size, but it's big on quality and performance. The Shortie is a direct replacement for the Mustang EcoBoost's standard blow-off valve.
The Plumb Back is a fully recirculating valve, so all vented air is routed back into the vehicle's intake. The Plumb Back offers all the benefits of a Turbosmart BOV, but with quiet operation, so it doesn't attract any unwanted attention.
The Shortie offers improved valve response thanks to its lightweight piston, while its precision billet construction gives better sealing and durability, and up to 30psi boost handling capability. That sharper valve response means boost builds faster, while the better sealing means it holds on longer, giving you more power throughout the rev range even in an otherwise standard car.
Quality is at the heart of every Turbosmart product, so the Shortie not only improves the performance of your EcoBoost engine, but it also guards against potentially damaging compressor surge - and will do so for a long time.
