Tuner can't tune my cai and has given up on me.
markmurfie
Hawaii
Mark
2015 Ford Mustang GT
markmurfie
Hawaii
Mark
NVM their opposite trends.
Stock tune is 10-15% rich at low airmass and normal only at higher airmass. trend is getting leaner.
JLT is 25-30% lean at low air mass and 10-15% lean at high air mass. trend is getting richer.
Kinda seems like injector data is not right. They might have contol, just not seeing what they expect as the injectors you said you are using are not the ones they are thinking of. I was mostly interested in seeing if they actually changed something with a revision.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
He sent me logs that say R1 and R2, pm me your email and I will forward them.
markmurfie
Hawaii
Mark
And yes, comparing MAFs from both logs its about a 95% change.
Confirming they made the correct expected change.
K4fxd
NKY
I had a set of LU47's that I could not tune. I waited too long and they were out of return window, so I tossed them in the trash. Chinese junk if you ask me.
tdstuart
tdstuart
Arizona
Triston
2015 Mustang Gt Premium
Interesting. Thought the lu47 were one of the best injectors for stock fuel pump and NA / low boost. Bought mine from lethal
Red65
MS
Red 1965 Coupe, 2017 Premium MT GT
They aren’t the best. They were a go-to in the Ford / Mustang community because they are cheap and they usually work for moderate applications. But there’s nothing really high-end about them. There are some far better options for E85 capable injectors like from Injector Dynamics.
K4fxd
NKY
Got mine from Lethal also. They are made in China.
I got a set of knock off NGK spark plugs from O'Reilly's too.
tdstuart
tdstuart
Arizona
Triston
tdstuart
tdstuart
Arizona
Triston
markmurfie
Hawaii
Mark
tdstuart
tdstuart
Arizona
Triston
Yes looks like they added 30% like they said.
Didnt see any change in fuel trims.
Not sure what else they could do for you.
So any ideas on what the issue could be? I really doubt it's the injectors. The stock air box seems to be great.
markmurfie
Hawaii
Mark
My guess is a bad fuel pump or clogged filter. It usually looks the same as bad injector data, because the inffer pressure data becomes inaccurate to the actual rail pressure. its nice the 18+ cars has a sensor now.
It certainly seems fuel system related.
The rich idle on your stock intake tune, doesn't let me think your car was great before the intake.
Seems like something was being compensated for in the higher airmasses.
I can't see all changes they made in the calibration. But it certainly seems like they were tring the right things.
tdstuart
tdstuart
Arizona
Triston
My guess is a bad fuel pump or clogged filter. It usually looks the same as bad injector data.
Did a quick search and couldn't find anything on replacing the mustang gt fuel filter. Is it a hard job? And is there any way to test the fuel pump?
K4fxd
NKY
As far as I know the S550 Only has a sock filter that attaches to the fuel pump.
