TUNE basic question
BranoSK
new jersey
brian
2015 mustang gt
Hi few weeks ago a i just got 2015 GT with manual transmission . There is already on car:
- jlt intake
- H pipe MBRP street version exhaust
-Eibach sportline springs
Probably lame question but :
Its there some way to check if there is TUNE on car? If not what is the best basic tune for this set up. (in budget kind of :) ) for every day ride lets say Thx for any advice.
shogun32
Northern VA
none of those mods are helped with a tune. So doubtful. Have a friendly mech look at the ECU flash count number. If you're not going to run E85 or 93 constantly then just put 91 in the tank and be happy. Otherwise buy the Ford Performance tune package if you care about factory warranty, otherwise get a 'used' tune device and give Unleashed Tuning a call.
AZ18yote
Arizona
Bryan
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Without a tune I'd be surprised if it ran at all.
You should have gotten the tuning device when you bought the car.
I'm not bashing Lund, but if it is a Lund tune good luck.
He scrambles the ECU
Jordan @ Lethal
Wellington
www.lethalperformance.com
Jordan
2016 Stingray M7
You most likely have a tune on the car with the JLT. Those intakes are a rather drastic change from the stock one and your MAF is calibrated to for a specific size intake. A dealership will be able to tell you specifically but assume that you do.
If you're interested in doing more mods to it in the future, you will need to get a tuning device, remove the current tune and upload another from your choice of aftermarket tuning like Lund or Palm Beach Dyno.
We offer a handful:
custom-tunes-1
Bluemustang
2015 Mustang Base GT
Actually sounds like you are.
K4fxd
NKY
Just stating facts.
Unless he has changed his locking system, not even Ford can overwrite it.
fatbillybob
SoCal
'19 GT pp1 A10 Orange
K4fxd
NKY
He changes the addresses so if you plugin you can't access the PCM.
Again unless he has changed his system.
BranoSK
BranoSK
new jersey
brian
2015 mustang gt
thanks for all replays
I don't have check engine lite and car pulling good so probably i ill not mess with any tune (probably some tune is already there)
But i should probably invest in some shifter update ( this shifter is kind of flimsy )
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
'17 S550
-Huh? I access the PCM no problem on my buddies LUND tune car. The software uses JAVA to encode it. They leave telltales if the tune 'magically' shows up somewhere.
fatbillybob
SoCal
You mean you can't plug your obd2 tester in there and pull codes or you can't say stick your HPTuner's MVPI2 in there and read/modify the tune (aka locked tune)?
shogun32
Northern VA
