Trufiber Hood A49-3 Carbon Fiber V6/EcoBoost/GT 2015-2017
CJ Pony Parts
Posts
1,290
Harrisburg, PA
www.cjponyparts.com
A large variety of Mustangs across all generations
Trufiber Carbon Fiber A49-3 Hood for 2015, 2016 and 2017 V6, EcoBoost and GT Mustangs.
If you're looking for an aftermarket carbon fiber hood for a 2015-2017 Mustang that's one of the best on the market, it's time to check out this hood from Trufiber. Not only is it made out of lightweight and durable carbon fiber, but it also features a removable built-in ram air kit and much more!
[ame="[MEDIA=youtube]FtxgQkacTlM[/MEDIA]"]
Features & Benefits:
- Vacuum-Infused Real Carbon Fiber That's Also Paintable
- 3K, 2 x 2 Twill Weave
- Show-Quality Finish and Clear Coat Finish with UV Protection Plus a Smooth Gel Coat Finish on the Bottom
- Built-In Removable Ram Air Kit
- Fully Functional Ram Air and Heat Extractor
- Cool Air Enters Open Air Scoop and is Directed to the OEM Air Box Location
- Hot Air Exits from Two Open Heat Extractor Vents That are Also Removable
- Comes with Reinforced Metal Latch and Hinge Plates for Additional Safety
- Integrated Stainless Mesh Grille
- Pre-Drilled Prop Hole
- Direct Bolt-On Installation Job (Bolts Included)
- Approximate Weight of 30 Pounds
This Trufiber TC10026-A49-3 Carbon Fiber A49-3 Hood offers you plenty of amazing advantages. It's made out of paintable vacuum-infused real carbon fiber with a 3K, 2 x 2 twill weave. But you don't have to paint it if you don't want to since carbon fiber looks great unpainted too! This hood also comes with a show-quality and clear coat finish with UV protection plus a smooth gel coat finish on the bottom and an integrated stainless mesh grille, and it weighs in at a mere 30 pounds.
You'll also get a built-in ram air kit that's removable, as well as two heat extractor vents that you can also remove. For extra safety, Trufiber reinforced the metal latch and hinge plates. They also pre-drilled the hole for your prop rod and included the bolts you'll need to install this hood.
Please Note: This hood will require the Trufiber Universal Windshield Washer Relocater Kit. Please see HW3494. Also, this hood does NOT ship pre-painted.
*This hood will NOT fit GT350/GT350R Mustangs.
*Although it is not required, it is highly recommended to invest in a set of hood pins to safely secure your aftermarket hood.
Order a Trufiber TC10026-A49-3 Carbon Fiber A49-3 Hood for your 2015-2017 V6, EcoBoost or GT Mustang from CJ Pony Parts today!
213 - Auto Mafia Racing
