If you change the ratio you will also need to reprogram for the change . Whipple flare tool will work for the changeI have the 15GT PP. I am thinking of changing gears from 3.73 to 3.55. I am told the differential is different from a base GT. Are the gears different too? Does it take a different style of gear?
Thanks
This. ^^^. Going to 3.55 is a waste of time and money. Just start in second gear.Same style gears. The differential in the base GT is a Traction Lok, which is a clutch style posi/limited slip differential. The Performance Pack uses a Torsen diff which is a worm-gear style (non clutch) limited slip unit. The Torsen is much better and does not have clutches to wear out. You can "simply" change the gears to 3.55 and use your current Torsen unit. (Your Torsen works with 3.31, 3.55 and 3.73 gear ratio's.. but not with the 3.15 ratio) There will not be a very significant change in performance between 3.55 and 3.73 gear ratios.
