To all FPRS Gt350 owners.
barstowpo
Witness Protection Prog
Helena, MT
Gordon
2016 DIB GT350 Tech/Track hybrid, 2016 FPRS Car#17
Like 16 others, you have a former Ford Performance Racing School car. (One of you lucky people bought 2) I am going to use mine relatively unchanged as a track car mostly. I am a little OCD and hate the air bag light illuminated on the dash. I also fear this will prevent me from buying an extended warranty since purchase requires an inspection. I pulled the interior apart and plugged most everything back in. My problem is there are plugs in the quarters that have nothing to plug into. Additionally, I removed the belt tensioners since they were just zip tied in the quarters so I have nothing to plug those plugs into either. Is there someone smarter than me who knows what resistors could me installed to trick the system into thinking the missing components are still there and thus eliminate the airbag light?
pilotgore
US
A bunch
Have you plugged the steering wheel air bag back in?
My FPRS tech told me they unplugged the crash sensors near the front bumper and the steering wheel airbag connector in order to keep the airbags from deploying if there was an ontrack crash.
The plugs in the quarters don’t plug into anything.
barstowpo
barstowpo
Helena, MT
Gordon
The ones that went to the belt tensioners did.
barstowpo
barstowpo
Helena, MT
Gordon
Unfortunately, I put the interior back together. I could take a picture of the removed tensioners I guess.
pilotgore
US
A bunch
I must be misunderstanding. When you said there were unused connectors in the quarters, I assumed you meant in the engine bay, up against the front fenders. My bad.
Slywilliez
NE ohio
Bill
Mustang gt
There are 2 air bag sensor that tie into the driver and passenger seat belt! First one is tied to the lap belt but the other is plugged into the retractable section in the quarter panel! I have plug all of mine in and still have the air bag light on! I had Ford scan it and it still shows the seat belt tensioner as the open circuit. I may have to remove the back half of the cage to fully remove the rear panel to test out the issue! I hope this helps!
barstowpo
barstowpo
Helena, MT
Gordon
I removed the seat belt tensioner. What I'm looking for is how to trick the system to think they are still there. Also the belts too.
dpAtlanta
Atlanta, GA
2019 GT350 (#K2503), 2017 Cayman
If they wanted to disable the entire airbag system, they most probably would have just unplugged the main yellow ACM (Air-Bag Control Module) connector. Unplugging this disables the entire system, and also illuminates the "Air Bag" light until it is reconnected to a functional ACM.
Trying to unplug every parameter sensor is a lot of work... why would they bother if the one plug does it all?
The ACM is approximately 4" x 5" x 1", and silver in color. It is located under the center console... if you see a yellow connector, you found it!
Slywilliez
NE ohio
Bill
Mustang gt
I already checked it, it was plugged in!
I don't know if this will help any, but it's the only airbag mapping diagnosis I have from a Ford Shop manual - I think it was 2017 S550. The airbag system has not changed drastically from 2015-current.
The S550 airbag system is very complex and any reset needs to be performed using the Ford IDS system. I'm not sure if the SRS system can be reset using the Forscan device.
This is the other diagnostic info I had posted a while back for folks rebuilding salvage S550's with airbag or non-start issues. The info within may also be helpful.
https://www.mustang6g.com/forums/th...cident-or-salvage-repair.165362/#post-3364334
Check these 2 areas for SRS issues, threads below for reference.
Knee air bag connections:
https://www.mustang6g.com/forums/threads/2018-gt-airbag-light-on-cluster.107200/page-3#post-3333786
Overhead map light air bag "jewel":
https://www.mustang6g.com/forums/threads/2018-gt-airbag-light-on-cluster.107200/page-2#post-3017970
Tomster
Beware of idiots
Tom
Reach out to kohr motoraports. I think they sell an airbag resistor for removing seats. I'm sure they would know what you needed.
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
I recently removed my seats for reskinning and now I have the dreaded airbag light. Ford App Lists every single issue that it could probably have, seat position, occupant, and airbag circuits. All the plugs are connected properly and no visible damage to any wires. Rechecked the side bolster airbag connection and it’s solid. Is it possible the system freaked out because I drove without the passenger seat installed and now it won’t reset without the dealer hooking it up?
barstowpo
barstowpo
Helena, MT
Gordon
Yes. Driving it unplugged will trigger the light. You'll need a proper scan tool to reset it.
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
That’s exactly what I ended up doing. Purchased a Foxwell 650 Elite diagnostic tool. Cleared the codes and all is well now.
