Tire replacement
hotrod33647
Wesley Chapel
2015 mustang gt PP
Looking to replace the rear tires and need suggestions. Money no object what would you buy and bang for the buck what would be a good recommendation. Finally, is there any performance advantage going wider (285 or 295 mm). Hindsight, one would think going wider would generate better grip but saw an old article where going wider didn't generate added performance so any suggestion is greatly appreciated. Happy New Year and a safe one to my fellow Mustang owners.
Advertisement
Wally
St. Petersburg, FL
2017 Challenger Scat Pack
I'm not trying to be that search nazi guy but you should check out the wheels and tires section of the forum. Tons of info to be found there. :cheers:
Rdot9
AZ
2016 Magnetic GT Premium w/ Performance Package
Michelin Pilot Super Sports. /Thread
Quackfoo
North East
2016 Black GT Premium
You really shouldn't run different brand/make tires on your car. Stick with the same brand/make or replace all 4.
Norm Peterson
corner barstool sitter
Norm
'08 GT #85, '19 WRX
MPSS. Near as I can tell, P-Zero fronts with MPSS rears will remain understeerish, possibly a little more so than P-Zeroes all around. Safe, but I'd plan on moving up to MPSS all around.
295/xx is out of spec for 9.5" wide wheels, don't look at these unless you're also looking at getting wheels at least 10" wide (and preferably 1/2", maybe 1" wider than that).
285/xx is (just barely) acceptable per tire industry standards, may cost you some steering precision on 9.5" wide wheels (10" or even 10.5" would be better).
Actual tread width frequently does not correspond to tire sizes/section widths. Example: 265/40-18 and 285/35-18 MPSS both claim to have a 10.2" tread width in spite of the 20mm size difference. You can even find cases where some narrower tire size actually has a wider tread than at least one wider size.
Norm
Advertisement
8 - UPR Products
Advertisement
