TheLion
Alright gents, I've been slowly pushing the car harder on some beautiful empty country back roads (no drive ways, clear views, two sweeping turns etc.) and I pushed it harder than I have before recently. I've noticed some characteristics that I'm not fond of.
Now there's obviously a bunch of things going on here and multiple aspects of geometry, spring rates, damping rates etc., so pleas do forgive me if I'm incorrect as I'm still learning the fundamentals of suspension geometry.
During hard cornering the car gives me a sensation that it's going to roll over which I'm NOT a fan of. My suspension modifications are very conservative at this point and as some of you know I'm planning a quite extensive over haul based on R&D testing BmacIL and few others have undergone and proven out, but I plan to do it piece wise so I can work through the changes and see how they impact the car's handling (well that and it's much easier on my wallet).
I have a 2016 PP GT 6M. I do have a Power Pack 2, cat back exhaust and oil catch can and am running Mobil 1 Advanced Synthetic, so the 5.0 runs pretty strong and consistent compared to when it was stock, keep that in mind as it's making a substantial amount more mid-range power that it didn't stock.
I am running BMR's SP080 springs for the time being, stock PP sway bars, camber / caster plates, CB05 cradle lock out and FP outer toe link spherical bearings. So the back end and front end are nice and tight.
1. This has been on my to fix list for a while, Tramlining with my +33mm offset lightweight wheels from RTR. Does tramline a very small amount with the stock PP wheels I'm currently running (so I can burn up the P Zeros), but it's less noticeable because of the smaller scrub on the stock offset.
2. A tipping sensation during hard cornering that I don't ever recall experiencing at the stock ride height with stock springs.
If my memory serves correctly, doesn't a lowered roll center (from lowering springs) increase jacking forces and body roll and is that why I get this "tipping sensation" during cornering? Normally lowering springs have a slightly higher spring rate to compensate to some degree, however the SP080's have nearly identical spring rates to stock, hence there's nothing to counteract the increased leverage on the suspension due to the lowered roll center.
It feels as if the inside tires just want to lift up and the car wants to roll over. But I have yet to hear of a GT rolling over during cornering, the CG is low enough that I would expect to break traction well before that point, especially on crappy stock P Zero's and stock PP wheels.
I'm seriously thinking about getting Steeda's roll center and bump steer correction kit for the following reasons (assuming I'm on the right path here):
1. If I am understanding how a lowered roll center affects the leverage on the suspension, lowering the car while keeping the same spring rates, damping rates and bars will increase body roll which also results in increased jacking forces that "lift" the car during cornering (pushing up on the roll center) and that's the "tippy" sensation I feel.
2. Bump steer obviously is an issue that gets exacerbated more by uneven surfaces, especially street use and causes car to tram-line due to excessive toe angle changes as the suspension moves through it's arc of motion. This will be exacerbated by a increased scrub radius which effectively amplifies the leverage on the wheel.
No I have NOT had an alignment yet, however I have a pretty good idea of approximately where the geometry is at and I don't believe an alignment is going to resolve the above issues unless some one can convince me other wise. So I'm holding off on a performance alignment until I decided weather or not to correct the roll center and bump steer, but I'd like have a good handle on these quirks I have introduced by lowering the car.
