Three Inch Exhaust Observations
Discussion in 'I4 2.3L EcoBoost Engine / Mods: Bolt-ons, Exhaust,' started by rvercitypony, Dec 30, 2017.
  1. rvercitypony
    rvercitypony Well-Known Member
    Vehicle(s):
    2016 Ford mustang Ecoboost
    Apr 19, 2016
    Riverside Califonia
    51
    I just had a 3 inch custom catback installed. I wish I had a picture of the
    design, but a Magnaflow muffle replaces the factory resonator, then a y-pipe splits into two 2.25. pipes with custom tips. I like the deeper tone at idle. It's louder thru the rev range, but it's refined. Performance wise, if there was an increase in hp/tq, it's negligible. These will probably increase after a updated tune. However, the car revs so much faster, like it had a rear gear change! Last, the design of the exhaust system must have shed 40 lbs., considering the combined weight of resonator and the stock mufflers.
  2. Brian V
    Brian V USA Retired
    Vehicle(s):
    2015ecoboost premium 201A Nav Sec Race Red
    Apr 27, 2015
    Native Earthling
    986
    156
    0   0   0
    What does it sound like ? A Yamaha ?
  3. OP
    rvercitypony
    Vehicle(s):
    Apr 19, 2016
    Riverside Califonia
    51
    Not at all. These cars are never going to sound like a V8, but my new exhaust kit has a pretty deep tone and no raspiness. Or crackles and pops during down shifts. Believe me, I was surprised at the results. I'm glad, because my with my 600 hp supercharged 2007 GT it took multiple attemt$ to get the sound I wanted.
  4. trippleyelo
    trippleyelo Well-Known Member
    Vehicle(s):
    ford f250 turbo diesel and 2016 mustang svo
    Sep 16, 2017
    vancouver wa
    504
    78
    0   0   0
    Wow bro..
    Do they have comedy night around ? you can go get practice there:clap2:
  5. TorqueMan
    TorqueMan Well-Known Member
    Vehicle(s):
    2017 EcoBoost Premium
    Aug 24, 2017
    St. Jacob, IL
    670
    196
    0   0   0
    Nope, a Kawazuki Ninja Turtle.
  6. TorqueMan
    Vehicle(s):
    Aug 24, 2017
    St. Jacob, IL
    670
    196
    0   0   0
    So you have a single muffler where the factory forward muffler used to be, with straight pipes aft. How does this mod affect exhaust sound on the highway? I use my car for commuting and long highway trips, so any droning would be a deal breaker for me.
    Also, can you give us an idea of the cost? It would be helpful if you could tell what your shop charges hourly as well.
  7. 5.0yote
    5.0yote AKA Bananana & 3.7Cyclone
    First Name:
    Don
    Vehicle(s):
    2016 Mustang Ecoboost Premium
    Jul 18, 2015
    Mansfield, MA
    612
    145
    Garage Profiles:
    Rating:
    100%
    6   0   0
    Once you have opened the exhaust at the down pipe, and tuned it your only going to squeeze out so much, but you will by removing the factory resonator help the turbo breathe far better than with it and you will gain slightly better spooling, and a hair more power up top but you really need to re-tune after removing that exhaust restriction you should be able to squeeze out a little more.
    I found on my big turbo setup the stock resonator ate up like 2-3 PSI boost on the MAP catless down pipe. Too much added back pressure when stock you can see that with the heat marks at the exit of the resonator and that's on a stock turbo. With the restrictive resonator it adds just too much back pressure and causes your exhaust gasses not to flow quickly or in enough volume on a 3" off road down pipe and it ruins scavenging as well. Its fine for the stock down pipe. There has to be a balance. Going from a 3" to a 3" and then y to 2.5" exits are about the right balance. (Too much exhaust slows it, you want it to push volume and be quick about it.) Hopefully the middle muffler is at least no smaller than 2.5" on its exit and 3" in the inlet. IT would be optimal to be 3" in/out.
  8. DontoMelbo
    DontoMelbo Well-Known Member
    Vehicle(s):
    Future EB Vert
    May 20, 2016
    East Coast FL
    Is it a custom install like what was installed in this link?
    https://tinyurl.com/k5ljn7w
  9. Elgyn
    Elgyn Well-Known Member
    Vehicle(s):
    2016 ecoboost, MT, DIB, Premium, PP
    Feb 11, 2017
    Vancouver, Canada
    232
    70
    0   0   0
    Is that a 2" pipe between the flex pipe and resonator?:eek:
  10. DontoMelbo
    Vehicle(s):
    Future EB Vert
    May 20, 2016
    East Coast FL
    Beats me its not my car! Looks like it though :headbonk:. I would also never install a press bent system...
  11. CustomS550
    CustomS550 Well-Known Member
    Vehicle(s):
    2016 EB Mustang
    May 10, 2016
    New Jersey
    301
    43
    Rating:
    100%
    1   0   0
  12. OP
    rvercitypony
    Vehicle(s):
    Apr 19, 2016
    Riverside Califonia
    51
    Sorry about the late response. I've Been away from the computer. Other than the two knuckle head ones in the thread, thanks for the responses. To answer the cost question, it was $500. To be more precise on the design, the muffler has a 3 in Y-pipe outlet which is reduced to 2.25. inches at the Y itself. Also, the Magnaflow muffler is large--it may be for a truck for all I know.. But it is a through muffler. Regarding any drone, it weirdly only occurs right at 2000 rpm and not above that while cruising. Under WOT it sounds great all through the rev range. While at idle and low rpm it has close to a Suburu boxer motor sound.
    TorqueMan and CustomS550 like this.
  13. CommyO
    CommyO Is it a v8?
    Vehicle(s):
    15 EB Premium PP
    Oct 11, 2015
    Blue State
    957
    386
    0   0   0
Loading...
Share This Page
