Thoughts on suspension upgrades
Alloy
S550 EB
I have an EB PP lowered on Eibach pro's with GT PP staggered Wheels. I will be installing the BMR CB005 kit along with Eibach front and rear sways.
1st question: will the Steeda Subframe alignment kit work with the CB005 kit?
2nd question: What would be your next purchase if you could only get one:
BMR Vertical links
BMR End links
BMR Adjustible Toe Rods
Rebellion
Houston
2016 Competition Orange GT
BMR Vertical links
BMR End links
1. No, you'll have to dump the front sleeves or cut them.
2. IMO, if I had to chose one of the 3, vert links.
EricSMG
San Diego
2017 GT w/PP, 2004 BMW M3 Coupe
You really don't need the alignment kit with the CB005 - that'd be redundant since the CB005 essentially aligns the cradle.
tj@steeda
Timothy
Steeda is currently working on a solution for the kit in the aforementioned ... we should have a solution shortly.
Best Regards,
TJ
wildcatgoal
@sirboom_photography
TBD
Of the options you've chosen, I'd get the BMR Spherical/Spherical vertical links. End links are not necessary for someone who doesn't actually need to squeak the last bit of handing control out of their car. I don't have end links with my aftermarket sway bars and I don't have body roll problems. Toe rods? Tons of guys go down a drag strip or around a track with great times and do nothing to their toe rods.
Performance nut
TX
2018 Mustang GT A10
Best Regards,
TJ
Care to elaborate? :gossip:
wildcatgoal
TBD
It will be an alignment kit that fits while the CB005 is installed.
BMR Tech
Tampa, FL
www.bmrsuspension.com
Dion
We are also testing a completely unique alignment system. I have it on my car right now.
It won't be available for a while, but I think we will eventually include it in the CB005 kit and offer it as a separate kit as well.
Alloy
S550 EB
Excellent info guys. I will place the order for the Vert links asap.
Alloy
S550 EB
So if you already have a CB005 then this new system can work as an add on?
BMR Tech
Tampa, FL
Dion
Alloy
S550 EB
@BMR Tech
Yup! :cheers:
I was about to order the Vertical links but saw that there were 3 different sets with 2 different prices. Could you please elaborate on the differences and applications?
Coyote Red
Port Lavaca,Tx.
Alan
2016 5.0 Coyote Red
My coyote goes"wild right" on launch so I am following this for sure. Seems we should wait for CB 005's add -on.
Alloy
S550 EB
"These are the perfect upgrade for the enthusiast looking to greatly improve performance without NVH levels being a concern."
I was about to make the purchase but saw the above line in the description. Was it saying that if you aren't worried about NVH levels then this is the part for you? As this is my DD last thing i want to do is add NVH.
BMR Tech
Tampa, FL
Dion
TCA045 and only the TCA045.
I have recommended anything else, zero times. I am not a fan of Delrin on vertical links.
NVH will not be an issue. I have about 1000 sets of these out there and can count on less than 5 fingers how many NVH issues I have dealt with, with these particular pieces. They really are the bees knees. ;)
