Mike Pfeifer
- Feb 4, 2021
- Wesley Chapel, FL
- Mike
- 2019 Ruby Red Mustang GT A10
Just to clarify, you have the 9 speaker system? It’s been shown a few times here and there that the B&O system already has the modification from the factory. So you would be changing nothing in that case. I did the modification in my 9 speaker car and it was an obvious change. This is what I have in my notes and what I followed:Can you tell me exactly what you changed with Forscan? As I mentioned in my earlier reply in this thread I've made this change twice and neither time could I tell any difference. Maybe I haven't changed the correct line, so I'd be willing to try it a third time if it really makes a difference. Thanks.
And then write the new info to the car, then the head unit will reset and then it should be good to go.***Remove bass roll-off from head unit: There is one code to change in module 727:
***727-01-02 00xx
***First two digits we want set to 0. This disables any EQ Processing, bass roll-off etc. (tone controls will still function as normal)
