TheLion
I just got done doing a rear end swap on my 2016 ecoboost. I put in a loaded GT PP rear diff (3.73 Torsen). However I also installed the steeda performance (black or stiff) differential bushings and aluminum sub-frame bushing stiffeners. It's obvious that there is markedly more noise, I hear all the drive train slop / backlash when starting or stopping at lower speeds, so please take note of that.
However I'm not familiar with Torsen differentials and what's normal and not. Basically I can only describe as a roaring or binding noise (similar to a tire rubbing inside a wheel well, but more metallic) when taking sharp corners are low speeds under moderate throttle (which happens some what often).
It does not occur on larger more sweeping turns and lessens the harder I am on the throttle, obviously if I floor it in 2nd going around a corner the torsen does its job and both rear tires break loose and fishtail the car (where my standard EB base diff would just produce inside wheel spin).
It's quite loud at times. The loaded differential was never disassembled, so it has factory shimming and pre-load on the diff bearings. The drive shaft flange was removed and swapped with the ecoboost flange that was on my stock diff as they are different (but mate to the same 30 spline pinions). The pinion bearings were set with proper pre-load and even so it only occurs during sharp cornering while under light throttle (aka daily driving), not in a straight line (no noise what so ever other than a barely audible whine at 77mph, but not a big deal). Coasting around a sharp corner it's either non-existant or barely noticeable as well (aka the diff is under no load). When I had the car up on stands, after I re-seated and alighned the sub-frame and reconnected the drive shaft, I did a rotation check and was easily able to rotate one axel (with the other axel rotating the opposite direction like an open diff) without any noise or binding, smooth as butter. I was also able to rotate the drive shaft easily (car in neutral) and both axles turned smooth as butter with no noise. So I verified there nothing external binding anywhere on the drive train or bearing issues just to be clear. This is coming from the torsen internally and it's more audible because of the bushings.
I'm running AMSOIL 75W-90, but I have not added in the friction modifier yet. AMSOIL said I their severe duty gear oil didn't require modifier but I could use the ford modifier or another (which I forget what it was called) if I have gear noise (although I think they were referencing gear whine, which is related to the pinion and ring gear).
Now I doubt I would hear much of that noise if I had stock diff / sub-frame bushings as they transmit quite a bit less noise (hence why you get wheel hop also). But I would like to quite it down some during sharp corner without changing to the softer red bushings if I can. Anyone notice this noise in your torsen (especially if you do diff / sub-frame bushing upgrades) and have you had any luck with friction modifier quieting down the "torsen sharp turn roar"?
