Idaho2018GTPremium
So I finally decided to pull the plug on some mods for my '18 A10 GT that I don't believe will risk any warranty issues if problems arise in the future. I've chosen the following 1st round of upgrades:
K&N Intake
Airflow solutions OEM ported throttle body (awaiting receipt)
Airflow solutions OEM ported intake manifold (awaiting receipt)
Borla S-type catback (received, awaiting install, car is not running now since the TB and IM are at Airflow solutions in AZ).
The K&N intake gained noticeable mass airflow increases, no tune required. My 30-70 mph time of 2.75 seconds is noticeably quicker than stock (only change being the K&N intake).
I went with the stock OEM ported TB and intake manifold to reduce risk of warranty issue compared to larger TBs that would require a tune, or swapping to the GT350 IM which would require the 87 mm TB, also requiring a tune. Plus, portinf my stock '18 IM and TB is MUCH cheaper than going with the GT350 intake and Bullitt TB. I didn't want to change the tune at this time for warranty purposes.
The Borla S-type - went with this due to the sound, and the good hp and torque gains seen by MotoIQ: https://motoiq.com/testing-borlas-s-type-cat-back-exhaust-for-the-2018-mustang-gt/
13 rwhp peak gains, and a massive 33 ft-lbs at the low end. That's some great low end and top end pickup for just a catback. Plus, it's 20 lbs lighter than the stock catback.
I also bought the Borla H-pipe resonator to use if the regular S-type X-pipe setup is too loud for me. I think the H-pipe will lose a few hp compared to the X-pipe setup, but may be worth it if it quiets it down enough, reducing too much unwanted attention during heavy throttle.
K&N Intake
