- Banned
Here is what Isaac said about installing just the cooler for TechPack.
The part number for the cooler kit itself is M-7095-M8S MSRP $695
https://performanceparts.ford.com/part/M-7095-M8S (Available today for order at any Ford Dealer, or Ford Performance Parts distributor)
The part number for the transmission is M-7000-M8S MSRP $4,800
If you are only purchasing the M-7095-M8S, you will need a 12V external pump and 6 AN lines. A pump similar to a Weldon 9200 would be ideal, with wide thermal operation capability, and a similar flow rate.
Although, local race-prep shops may have experience and suggest other pumps, and fitment capability if your Ford dealer isn’t interested in installing the pump in your GT350.
For a list of all of our Ford Performance Parts distributors, see the link below, or click the “Where to Buy” link for a directory
https://performanceparts.ford.com/wheretobuy/
Keep in mind, we have not actually fitted a pump to a GT350, and recommend using an experienced installer if possible.
We have not fitted these components. This is a suggested list of components given my experience building racecars. I do not have any pictures or any instructions. I recommend a race shop or a mechanic with experience making/installing AN lines. The factory lines have to be cut and transitioned to the AN lines.
For 6AN lines.
Fittings at trans:
(2) 6AN x 1/2" NPT straight adaptors [Earl's 981668]
(2) 6AN x 90 degree hose ends swivel type [Aeroquip FCM4032]
Fittings at pump:
(2) 6AN ORB (O-ring boss) x 6AN [Russell 670840]
(2) 6AN x 90 degree hose end swivel type [Aeroquip FCM4032]
SS hose/hardline transition:
(2) 6AN x 1/2" tube braze fitting [Aeroquip FCM2873]
(2) 6AN straight hose ends [Aeroquip FCM1012]
Hose:
10' to 15' of 6AN stainless braided hose [Aeroquip FCA0615 for 15' length]
Pump:
(1) Weldon 9200A pump + wiring, switch, connectors.
(1) mounting bracket to be fabricated by installer
For 8AN lines.
Fittings at trans:
(2) 8AN x 1/2" NPT straight adaptors [Earl's 981688]
(2) 8AN x 90 degree hose end swivel type [Aeroquip FCM4433]
Fittings at pump:
(2) 6AN ORB x 8AN [Russell 670930]
(2) 8AN x 1/2" tube braze fitting [Aeroquip FCM2874] -OR- (2) 8AN x 1/2" tube adaptor [Earl's 165008] -OR- (2) 8AN flareless tube nut [Aeroquip FCM 2498] + (2) tube ferrule [Aeroquip DCM2493]
(2) 8AN straight hose ends [Aeroquip FCM1013]
Hose:
10' to 15' of 8AN stainless braided hose [Aeroquip FCA0815 for 15' length]
Pump:
(1) bracket to be fabricated by installer.
Isaac Ireland
Ford Performance
For 6AN lines.
Fittings at trans:
Fittings at pump:
Hose:
Pump:
For 8AN lines.
Fittings at trans:
Fittings at pump:
Hose:
Pump:
Isaac Ireland
Ford Performance
