Team beefcake racing's 2018 Mustang GT dyno
beefcake
beefcake
Bethel
2018 Ford Mustang
Nanashii
US
Mustang
Here is a snip of the graph from the FB video. The red lines are the 6th gear pull. We really need someone to run it to 7500 RPMs.
beefcake
beefcake
Bethel
2018 Ford Mustang
Well be getting after it soon
Eritas
Obsol3te
Hope Mills, NC
'15 GT PP
2015 3.55 and 4th gear pretty much equal the gearing of the 2018 7th gear 3.15.
So pretty good comparison.
Did the same SAE correction factor was apply to the 2015 like it seem to have been for 2018?
Looking forward to see a 7th gear pull with only speed and transmission 7th gear rpm limiter remove!!
1:1 is 1:1
The only thing left to compare is rear end gear and tire diameter at that point.
Unless you're saying the 15 has a substantially taller tire than the 18
Eritas
1:1 is 1:1
Changing the final drive ratio, tire diameter, tire (and wheel) weight will all affect the Dyno #s.
steph93lx
Montreal area
2018 GT 301A A10, Modded N/A 1993 coupe 5.0L
1:1 is 1:1
4th gear is not 1:1 it's 1.14:1 in the 2015. Because of the 3.55 it's a good comparison to the this 2018 1:1 and 3.15.
RoadCone
Ohio
2016 Competition Orange PP
I was there and I can say it was most impressive for a bone stock car. It took mine a tune and CAI to hit those numbers with a manual. I cant wait to see a build with one of these cars.
Beefcake, I would like to see you try NA first with my combo and see what it made! That Could be a monster. Just a thought.
beefcake
beefcake
Bethel
2018 Ford Mustang
guys, here is a better pic of our dyno run.
for comparison sake, at our pic on the 7th gear pull, when laying it over the 6th gear pull, you see that the 6th gear pull continued to make 11-12 more rwhp after that point.
which realistically means, we should see about 412-413 with the limiter removed
Eritas
THANK YOU. But why didn't you take it to its 7,500RPM redline? It looks like it would make even more power since the power was still climbing when you cut it short at 6,900RPM.
Anthony 05 GT
Northern Harford County Maryland
2005 Mustang GT, 2015 Mustang GT Premium
Looks like it levels off at 5500-6k not that it isn't still pulling, just levels off at least in the 2nd graph
