Switching out interior LEDs - blown fuse - replacement not working
Discussion in 'Cosmetic/Visual Mods (Exterior + Interior)' started by Aurum, Jan 20, 2017.
  1. Aurum
    Aurum Well-Known Member
    Vehicle(s):
    Jun 6, 2015
    Los Angeles
    217
    59
    0   0   0
    So I'm doing the Diode Dynamic/Raxiom LED upgrade mod.
    Of course I blew out a fuse and the trunk, vanity mirrors, and glove box lights no longer work.
    I replaced the 10a micro2 fuse but none of them are lighting up still. It's my first time replacing a fuse -- its securely inserted. Is there a wait time before power comes back or did I do something worse?
  2. Chef jpd
    Chef jpd Well-Known Member
    First Name:
    Vehicle(s):
    2016 EB P PP CO
    Apr 1, 2016
    Brooklyn, NY
    2,238
    1,106
    Garage Profiles:
    Rating:
    100%
    3   0   0
    they should come right back on, no waiting.
    Did the new fuse blow when you inserted it?
    If so, you have a dead short at the point that the fuse blew the first time.
  3. jbailer
    jbailer Well-Known Member
    First Name:
    Joe
    Vehicle(s):
    May 1, 2015
    3,274
    1,274
    Rating:
    100%
    1   0   0
    ^^^ This. My bet is the glove compartment. Changing that bulb was a PITA and not worth it. Possible something is shorted in there if the new fuse blew.
  4. OP
    Aurum
    Vehicle(s):
    Jun 6, 2015
    Los Angeles
    217
    59
    0   0   0
    If I remove all the lights and pop in a new fuse, will I be able to diagnose that way or will the dead short fry the fuse regardless of whether there's a light inserted?
  5. jbailer
    First Name:
    Joe
    Vehicle(s):
    May 1, 2015
    3,274
    1,274
    Rating:
    100%
    1   0   0
    If for example when you pushed the new bulb in, you mashed the 2 contacts together and they are stuck like that, it will keep shorting.
    If the bulb is just pushing the 2 contacts together, it's possible they will separate when you remove the bulb.
    Either way, removing the bulb is definitely the first step. Check the fuse with an ohm meter or fuse tester. Again, I would definitely start with the glove compartment light. A lot of people blew fuses installing that bulb.
  6. OP
    Aurum
    Vehicle(s):
    Jun 6, 2015
    Los Angeles
    217
    59
    0   0   0
    I can't even see the connectors in the glove box. Is there a way to remove the assembly?
  7. Chef jpd
    First Name:
    Vehicle(s):
    2016 EB P PP CO
    Apr 1, 2016
    Brooklyn, NY
    2,238
    1,106
    Garage Profiles:
    Rating:
    100%
    3   0   0
    Might be easier to see if you swing the glove box door down.
    Squeeze the sides at the stops when it is open and it will swing straight down.
  8. OP
    Aurum
    Vehicle(s):
    Jun 6, 2015
    Los Angeles
    217
    59
    0   0   0
    Thankfully it wasn't the glovebox. It was the trunk light. Super easy fix when I realized that the two connectors were touching.
    Thanks for the help.
    Btw, is it normal for the trunk LED housing to jiggle a bit? I thought it was originally super secure/tight before upgrading the LED.
  9. BlueThunder
    BlueThunder ***ding Rookie
    Vehicle(s):
    2018 Silver Mustang PP1 Manual (former 2015 GT Auto)
    Jul 9, 2016
    Long Island, NY
    602
    251
    Rating:
    100%
    1   0   0
    Yeah it'll jiggle a bit. Not sure how you mashed up the trunk one, that's the easy part. The glove box one is a bitch if you don't remove the assembly first.
  10. MakStang
    MakStang Well-Known Member
    First Name:
    Makis
    Vehicle(s):
    A 2017 miraculous little beast
    Dec 11, 2016
    Greece
    1,678
    253
    0   0   0
    I also just blew the same fuse while replacing the bulb in he trunk light with a led one. This seems to be a common issue with people replacing the bulb in the trunk or in the glove box. For other people to know, it’s fuse #1 in the fuse box located in the passenger’s compartment.
Loading...
Share This Page
