Swapping out GT Premium Seats for Base/Recaro
ripto
CT
2017 Mustang GT Premium
Does anyone know what I may have to do in order to install either the cloth base or Recaro seats in my GT Premium with the heated/cooled leather seats? I would assume it would require some work to the wiring harnesses.
white15gt
Michigan
White 2015 GT
It's a plug-and-play swap. Unbolt old seat, disconnect wires, bolt in new seat, connect wires.
ripto
CT
I don't think that's true. Base/Recaro don't have wiring for heating/cooling/power movement. Right?
1slo5ohh
Baltimore
18 GT
Recaros are manual seats so just unbolt and unplug your seats and bolt in the recaros. You won't have heated/cooled seats anymore obviously, but it won't hurt anything not having the harness unplugged.
Moostang83
Tallahassee,FL
2017 Mustang GT
How much are base GT recaros if you dont mind me asking. I have a base and regular and wouldnt mind looking into a swap. All i see are for the leather recaros when shopping around. Thanks
ripto
CT
No codes for no more heating or cooling, or airbags?
MikeMM
VT
2021 GT500 on order
My 15 GT premium had the leather Recaros and the wiring harness for the heated and cooled seats was just sitting there. Shouldn't affect anything.
ripto
CT
Interesting. Thanks.
MikeMM
VT
2021 GT500 on order
From what I've seen on all of my new cars, (I'm on #8), when they build them initially, they wire and prep the car to be fully loaded electrically, then spec the car down from there as far as options. So all the wiring and fuses have always been there for things like power/heated/cooled seats, steering wheel, moonroof, etc., even if the car didn't have them installed.
Racerx009
North Carolina
Anthony
2017 Ford mustang gt non pp
Cloth seats Sux
Vegas5OH
Las Vegas
2016 5.0 PP
i swapped from premium seats to leather recaros. There are two plugs under the seats one for heating and cooling and one for airbags, you just plug the airbag plug into the recaros and leave the heating and cooling plug un plugged. no codes or anything.
ripto
CT
Thank you. Where did you find your Recaros? Did you swap out all seats?
Vegas5OH
Las Vegas
2016 5.0 PP
I finessed a friend to trade me out before he traded in his car so i got them free. I swapped just both front seats because the rears are the same seat, and just so everybody knows factory recaro cars do not have the plug to swap in heated and cooled seats.
zackmd1
Zack
I have a 2018 with stock base seats if you were interested in a trade.... All connections should still be the same and you will not throw any codes.
ripto
CT
Front and rear? Can you post pictures?
