tyshenry
Yes, works just fine. Not sure what about any wheel wouldn't work with extended studs and open ended lug nuts.Will the extended length ARP studs and open ended lugs work with these wheels?
Do you have any photos of the new wheels on you car?I used small diameter (non tuner style) chrome Gorilla lug nuts
no good ones, I'll post a few shortly, but we have a snow storm headed our way, may be a few daysDo you have any photos of the new wheels on you car?
I'm particularly interested in the fitment on the rear.
Thanks!
+1, also interested in fitment on the rear.Do you have any photos of the new wheels on you car?
Thanks!
Now I'm confused. You're the first that I've seen say they needed spacers on the front, even with bigger/wider tires. LMR even sells them with 285/35/19 for the front. Was the tire actually hitting your strut? Looks like I may need to pick up a set of spacers, just in case.EB non PP 19x10 with 275/35/19 Michelin PSS. Needed a 5mm spacer upfront to clear the strut.
You have about a 0% chance of hitting the strut with a 19x10 +40 wearing a 275.Now I'm confused. You're the first that I've seen say they needed spacers on the front, even with bigger/wider tires. LMR even sells them with 285/35/19 for the front. Was the tire actually hitting your strut? Looks like I may need to pick up a set of spacers, just in case.
I'd grab a set of these, that's a nice price! Need to sell a couple sets of wheels first though.FYI, the 19x10 square set up is back. I just ordered mine.
https://lmr.com/item/WK-166902A/mustang-gt350-wheel-kit-19x10-gloss-black-15-17
the rubbing was said to be with a 285, NOT a 275, that being said, I have 285's on the front with my SVE gt350's, no rubbing for me........You have about a 0% chance of hitting the strut with a 19x10 +40 wearing a 275.
LMR6, got 6% off with that.I want to pick a set of these SVE's up. What site do you guys recommend? Thought I read something about a discount code but never found a code.
Negative. Look back at the quote in the post that i quoted. Said that 275/35 MPSS needed a 5mm spacer to cleae the strut.the rubbing was said to be with a 285, NOT a 275, that being said, I have 285's on the front with my SVE gt350's, no rubbing for me........
my bad, not even sure how he's having that issue, I run that same wheel up front, but with a 285, I have no rubbing :shrugs:Negative. Look back at the quote in the post that i quoted. Said that 275/35 MPSS needed a 5mm spacer to cleae the strut.
