DeepImpactS550
- Feb 28, 2016
- Longwood, FL
- 2016 Mustang V6
I was on the way home from work tonight when weirdness ensued. I had shifted into 2nd gear (manual trans) a bit low, at about 1800RPM. I rolled on the throttle, then suddenly the car bucked as-if I had let off the gas, then quickly blipped it. It then started sputtering and spitting, running rough like it had a multiple misfire. There was no response to the gas pedal, and RPM stayed at about 2500, regardless of pedal position. I looked at the dash, and saw a wrench icon, and [See Manual] displayed, with no other info.
I pulled into a turn lane, put it into neutral, stopped, and shut the engine off. I had to press the start/stop button twice to get the engine to stop. When I restarted the engine, it took 10-12 rotations before it started. I actually thought it wasn't going to start. Afterward it seemed to run OK. It was maybe down a bit on power, but by the time I got home the power was coming back.
There are no check engine lights, and I doubt I'll find anything in the manual, as suggested. Any ideas?
