Strategies to keep cats from melting
Torinate
Torinate
Ontario
2016 GT Convertible
That’s awesome! Who’s doing the install?
Grimreaper
Dallas
2017 GT
That's a very interesting piece of the puzzle. Have you been able to get the ex temp model to accurately match your probes?
Staged COT might be a doable option to limit the ramp rate. 2 points gives you a slope to play with. All the tunes I can recall always have the same temps in both stages. Would prob need to remove the mani and o2 sensor temp protection.
engineermike
La
2018 GTPP A10
It's impossible with the tune parameters we have. I could if it were offset or proportional error, but there is a time component of the algorithm that can't be adjusted. The best I could do is keep the mid-bed temp below a desired number and find a good COT time/power balance.
I've messed with the staged COT and not much changed in the behavior. And both are based on hard setpoints, not rate of change. I think the best we can do with the parameters we have available is to add fuel and enrichment rate at the right times.
engineermike
La
2018 GTPP A10
Since gt500 cats were brought up in post #2, I thought I would share what I learned today after purchasing some stock gt500 cats from another forum member.
The gt500 cats are the same diameter and length as stock cats. The rear o2, however, is fully exposed and doesn’t live inside a vented sleeve like coyote. Also of note is that the gt500 cats appear to be 400 cpi (20 x 20 cell in an inch) and the cells are square. The coyote cats are hexagonal cell 25 x 30, or 750 cpi, if my counting is correct. I can’t tell if the material is different.
For reference, in the attached pic the stock gt cat is on the right and it’s a failed one of mine. Gt500 is on the left and appears to be intact.
Angrey
Coral Gables
2016 GT350
Great work.
Would be interesting to see if the yield is different for the same flow.
Ostensibly, if they're the same material/catalyst, the denser array would not only oxidize more hydrocarbons, it would also be much more restrictive to flow and result in greater pressure delta.
Perhaps they're a different material and the less dense array is able to achieve better catalyzation while simultaneously reducing flow restrictions. Or perhaps Ford is allowed more pollutants as part of a fleet wide scoring. Does anyone know if the GT500 pays the "Gas Guzzler" tax? I wonder if said tax counts for not just economy, but pollutants as well.
Dave2013M3
El Segundo,Ca
2020 Ford Mustang GT Base PP1 6MT Rapid Red
A lot of is dictated by the kind of subtrate the cat has, not just the CPI. From the looks of the GT500 cat it looks to be of a much higher quality, and it probably needs to be as the GT500 with its boost.
Torinate
Torinate
Ontario
2016 GT Convertible
Yes. Wow! Does loom a lot thinker. Would the square design also be inherently stronger than a hex design?
How many miles roughly on both these?
engineermike
La
2018 GTPP A10
My gut says the hex geometry is mechanically stronger for the same thickness and cell count, but that’s a huge difference in thickness.
The gt500 have 10k and was stock. The gt was a bad comparison; not sure the mileage but nowhere near stock setup.
