Stock 2016 mustang GT premium rotor
Bflem55
Ohio
Brian
2016 Ford Mustang GT Premium
I currently have a 14 inch rotor on my 16 GTP can that be upgraded to a 15 inch rotor with a 6 piston caliper ?
TrackMustang
SoCal
2021 Mustang GT
Depends on your rims. The offset is what matters. I have the 19” rims that come with the black accent package and was told the 15” rotors and 6 piston calipers will fit.
NightmareMoon
2016 Mustang GT PP
Yeah, assuming your wheels allow it, you can upgrade to the bigger brakes. There are some packages for sale to make this switch.
EFI
Masshole central
5.Br0
Yes, you just need the correct hardware and wheels that will clear the larger calipers.
You can also go with a GT350 caliper and either 15" or 15.5" rotors pretty easily, but again those require wheels that clear them.
Bikeman315
Myrtle Beach, SC
Ira
Bflem55
Ohio
Brian
Any idea if I can use the stock caliper bolts or will I need to use different ones? I’m trying to purchase new ones and I don’t know which ones to order.
EFI
Masshole central
5.Br0
The caliper bolts are the same. Just make sure to re-apply blue loctite on them if you're going to reuse. Otherwise it's #10 here:
https://www.tascaparts.com/oem-parts/ford-caliper-mount-bolt-w716471s439?c=Zz1icmFrZXMmcz1mcm9udC1icmFrZXMmbD0xNSZuPUFzc2VtYmxpZXMgUGFnZSZhPWZvcmQmbz1tdXN0YW5nJnk9MjAxNiZ0PWd0JmU9NS0wbC12OC1nYXM=
Bflem55
Ohio
Brian
