Biggsy
Not sure is you know but Anderson has two variations of the R wing. They have the GR 350 wing and the OE which is an exact replacement as the OEM R wing. I have the GR 350 wing and you are correct that the two spoilers don’t line up. You would have to drill new holes to accommodate the Verus wing. But it will cover the holes.I have an Anderson Wing. Do those holes match? They had to be drilled into my trunk but Anderson says the wing isn't a direct OEM replacement for the GT350R wing. Also I don't have the support bars so I'll have to fabricate something I suppose.
I am in the market for an adjustable wing as I'm having high speed tramline problems and cannot adjust my rear downforce.
It is possible to use the Verus wing without the bars but you can definitely make your own
